Gateway NV52 Keyboard Replacement
Выберете то, что вам нужно
  1. Gateway NV52 Keyboard Replacement, Battery: шаг 1, изображение 1 из 1
    • Turn the laptop on its backside with the stickers and barcode facing you.
    • Locate the latches on the top left corner.
    Спросите у FixBot
    Добавить комментарий
  2. Gateway NV52 Keyboard Replacement: шаг 2, изображение 1 из 1
    • In order to unlock the battery, slide the vertical latch downward where it indicates the unlocking icon.
    Спросите у FixBot
  3. Gateway NV52 Keyboard Replacement: шаг 3, изображение 1 из 1
    • Slide the horizontal latch to the right to pop open the battery pack.
    Спросите у FixBot
  4. Gateway NV52 Keyboard Replacement, Keyboard: шаг 4, изображение 1 из 1
    • Remove the five identical 9/32" Phillips Screws located under the battery and both upper corners using the Phillips #0 Screwdriver.
    Спросите у FixBot
  5. Gateway NV52 Keyboard Replacement: шаг 5, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Heavy-Duty Spudger
    • Flip the Device so the keyboard and display screen are faced upright.
    • Lift up the media button board cover using the Heavy Duty Spudger. Apply a minimum amount of upward force to the media button board cover at the right bottom corner. Starting from the right, continuously lift the cover to the left edge until completely separated.
    • Do not lift up the media button board cover too much, it’s still connected to the motherboard. Set the media button board cover upside down on the keyboard.
    Спросите у FixBot
  6. Gateway NV52 Keyboard Replacement: шаг 6, изображение 1 из 1
    • Disconnect the dark colored locking tab by pulling at a 90 degree angle, and then slightly pull away the ribbon from the locking tab.
    Спросите у FixBot
  7. Gateway NV52 Keyboard Replacement: шаг 7, изображение 1 из 1
    • Lift up the keyboard with the Spudger. Rotate the keyboard until its faced down on top of its base.
    • The keyboard is still connected to the access keyboard connector, so do not attempt to detach the keyboard from the laptop, yet.
    Спросите у FixBot
  8. Gateway NV52 Keyboard Replacement: шаг 8, изображение 1 из 1
    • Disconnect the brown-colored locking tab by pulling at a 90 degree angle and slightly pulling away from the locking tab.
    • Do not apply too much force to the locking tab, because a damaged connector will disable the keyboard.
    • Remove the keyboard, and placed it in a safe and dry place.
    Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Tim En
Участник с: 01/26/13
557 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 7-24, Regan Spring 2014 Участник Cal Poly, Team 7-24, Regan Spring 2014
CPSU-REGAN-S14S7G24
4 членов
Автор 18 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 41
За всё время: 2,691
