Введение
If your service cover is damaged or you need to access internal parts, follow this guide to remove and/or replace the service cover.
Выберете то, что вам нужно
Remove the four screws from the back cover with a Phillips #0 screwdriver.
Next you will gently remove the cover by prying it off with a plastic opening tool.
