Введение
Procedure for dissembling the outer casing of the laptop safely.
Выберете то, что вам нужно
Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
Remove the twelve 5.9 mm Philips screws from the back cover.
Remove one 8.8 mm Philips screw from the back cover.
Unscrew the two 5.9 mm Philips screws located on the the side closest to the battery.
Unscrew the three 3.6 mm Philips screws that are within the Disk drive port.
Using the spudger, detach the connector by pushing two tabs away from the white connector and then gently pulling the connector away.
Unscrew the five marked 3.8 mm Philips screws.
Three screws are located on the right side of the screen.
Two screws are located on the left side of the screen.
Remove the four 5.9 mm Philips screws as indicated:
There is one somewhat hidden screw on the left side under the screen hinge, and one to the right of the (left)speaker, right/top side of the video port on mobo.
There are two similarly positioned screws on the right side.
The following steps (18 - 20) explain how to remove the three indicated connections.
The order is Blue, Violet, Orange.
Lift the white tab up and gently take out the connector.
6 человек успешно провели ремонт по этому руководству.
