Введение
Replace a broken screen in your Gateway SA1 laptop.
Выберете то, что вам нужно
Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
Remove the hinge covers by lifting each with the sharp point of the spudger.
Remove the six screw covers on the front bezel with the sharp point of the spudger.
Remove the front bezel by prying it off with the wedged end of the spudger.
The screen inverter is now exposed below the LCD.
Remove the single 3.8mm Phillips screw mounting the screen inverter to the computer.
Remove the six screws that mount the screen to the hinge mounts.
Two 2.5 mm Phillips screws.
Four 3.8 mm Phillips screws.
Remove the four 2.8 mm Phillips screws that secure the screen to the mounting bracket using a screwdriver.
2 человек успешно провели ремонт по этому руководству.
