General Electric Create Jason Wu Battery Replacement
Выберете то, что вам нужно
    1. General Electric Create Jason Wu Battery Replacement, General Electric Create Jason Wu Casing Disassembly: шаг 1, изображение 1 из 3 General Electric Create Jason Wu Battery Replacement, General Electric Create Jason Wu Casing Disassembly: шаг 1, изображение 2 из 3 General Electric Create Jason Wu Battery Replacement, General Electric Create Jason Wu Casing Disassembly: шаг 1, изображение 3 из 3
      • Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
      • These screws were missing in our example. These screws should have been small Phillips PH000 screws 1.5mm in length.
      • These screws are very small. To keep from losing any pieces, place all small metals on a magnetic project mat.
      Спросите у FixBot
      Добавить комментарий
    2. General Electric Create Jason Wu Battery Replacement: шаг 2, изображение 1 из 2 General Electric Create Jason Wu Battery Replacement: шаг 2, изображение 2 из 2
      • After the screws are removed, pull the front casing up and away from the camera.
      • If the casing is difficult to remove, use a plastic opening tool to gently pry up on the front as shown.
      Спросите у FixBot
    3. General Electric Create Jason Wu Battery Replacement: шаг 3, изображение 1 из 3 General Electric Create Jason Wu Battery Replacement: шаг 3, изображение 2 из 3 General Electric Create Jason Wu Battery Replacement: шаг 3, изображение 3 из 3
      • Using your hands or an opening tool, pry off the silver frame, taking special care at the top of the camera where the buttons are as it is a little harder to pry off.
      • If the back casing is loose from the camera body, it may be easier to perform step 4 first, then accomplish this step. Proceed as your unit allows.
      Спросите у FixBot
    4. General Electric Create Jason Wu Battery Replacement: шаг 4, изображение 1 из 3 General Electric Create Jason Wu Battery Replacement: шаг 4, изображение 2 из 3 General Electric Create Jason Wu Battery Replacement: шаг 4, изображение 3 из 3
      • The last part of the casing to disconnect is the back that houses the LCD screen.
      • The screen is attached by a connection ribbon. Gently pull the casing and screen away from the camera body to disconnect the casing.
      • The LCD screen is held onto the back casing by a small amount of adhesive. This may come loose during this process. Do not worry if they become separated.
      • This plug and the connection ribbon are fragile, try not to tear the connection ribbon when disconnecting.
      Спросите у FixBot
    1. General Electric Create Jason Wu Battery Replacement, General Electric Create Jason Wu Interior Disassembly: шаг 5, изображение 1 из 3 General Electric Create Jason Wu Battery Replacement, General Electric Create Jason Wu Interior Disassembly: шаг 5, изображение 2 из 3 General Electric Create Jason Wu Battery Replacement, General Electric Create Jason Wu Interior Disassembly: шаг 5, изображение 3 из 3
      • After the casing is removed, use your fingers to carefully lift up on the rubber pad, if it didn't already fall out during step 4.
      • The pad isn't secured to the camera so it will lift up and pull away easily.
      • After the pad is removed, the 2 Phillips head screws holding the control board will be exposed.
      Спросите у FixBot
    2. General Electric Create Jason Wu Battery Replacement: шаг 6, изображение 1 из 3 General Electric Create Jason Wu Battery Replacement: шаг 6, изображение 2 из 3 General Electric Create Jason Wu Battery Replacement: шаг 6, изображение 3 из 3
      • Using the Phillips precision screwdriver with the PH000 Phillips bit, remove the two 1.5mm screws.
      • Although the 2 screws are removed, the button board is still attached with a connection ribbon.
      • With a firm grip towards the bottom of the control board, gently pull away from the camera, removing the ribbon from the connector.
      Спросите у FixBot
    3. General Electric Create Jason Wu Battery Replacement: шаг 7, изображение 1 из 3 General Electric Create Jason Wu Battery Replacement: шаг 7, изображение 2 из 3 General Electric Create Jason Wu Battery Replacement: шаг 7, изображение 3 из 3
      • Locate the six 1.5mm Phillips screws that are holding on the interior camera frame.
      • Using the Phillips precision screwdriver and the PH000 Phillips bit, remove the 6 screws.
      • With the screws removed, the interior frame will no longer be fastened to the camera body and can be lifted up and away.
      Спросите у FixBot
    1. General Electric Create Jason Wu Battery Replacement, Battery: шаг 8, изображение 1 из 2 General Electric Create Jason Wu Battery Replacement, Battery: шаг 8, изображение 2 из 2
      Инструмент, используемый на этом этапе:
      • Using the Curved Precision Tweezers, detach battery plug from socket.
      • Some may find the tweezers unnecessary for this step and instead may use their fingers to gently detach the plug.
      Спросите у FixBot
    2. General Electric Create Jason Wu Battery Replacement: шаг 9, изображение 1 из 3 General Electric Create Jason Wu Battery Replacement: шаг 9, изображение 2 из 3 General Electric Create Jason Wu Battery Replacement: шаг 9, изображение 3 из 3
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      • Swap the 3.0 Flathead bit into the precision screw driver.
      • On the front of the camera locate the small rectangular slot where the battery is exposed.
      • Use the flathead bit to gently pry on the battery to start pushing it out of the camera, allowing it to become loose.
      • Do not pull the battery out too hard or the wires will break.
      Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Kailee Poe
Участник с: 01/18/17
274 Репутация
Автор 2 руководств
Команда
Eastern Washington University, Team 2-6, Crane Winter 2017 Участник Eastern Washington University, Team 2-6, Crane Winter 2017
EWU-CRANE-W17S2G6
4 членов
Автор 63 руководств
4 Комментарии к руководству
Hi, when reassembling, do you need to re glue the ribbon that was taken out in step 4.
Regards
Paul
Paul Lynch - Ответить Поделиться
where can you buy battery for camera?
shay.1 - Ответить Поделиться
type battery please. the photos battery blur
AND I - Ответить Поделиться
Hi,
Do you know where I can find the battery ?
Bruno Diraison - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 25
За всё время: 1,365
