General Electric Create Jason Wu Casing Disassembly
Выберете то, что вам нужно
    1. General Electric Create Jason Wu Casing Disassembly, General Electric Create Jason Wu Casing Disassembly: шаг 1, изображение 1 из 3 General Electric Create Jason Wu Casing Disassembly, General Electric Create Jason Wu Casing Disassembly: шаг 1, изображение 2 из 3 General Electric Create Jason Wu Casing Disassembly, General Electric Create Jason Wu Casing Disassembly: шаг 1, изображение 3 из 3
      • Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
      • These screws were missing in our example. These screws should have been small Phillips PH000 screws 1.5mm in length.
      • These screws are very small. To keep from losing any pieces, place all small metals on a magnetic project mat.
      Спросите у FixBot
      Добавить комментарий
    2. General Electric Create Jason Wu Casing Disassembly: шаг 2, изображение 1 из 2 General Electric Create Jason Wu Casing Disassembly: шаг 2, изображение 2 из 2
      • After the screws are removed, pull the front casing up and away from the camera.
      • If the casing is difficult to remove, use a plastic opening tool to gently pry up on the front as shown.
      Спросите у FixBot
    3. General Electric Create Jason Wu Casing Disassembly: шаг 3, изображение 1 из 3 General Electric Create Jason Wu Casing Disassembly: шаг 3, изображение 2 из 3 General Electric Create Jason Wu Casing Disassembly: шаг 3, изображение 3 из 3
      • Using your hands or an opening tool, pry off the silver frame, taking special care at the top of the camera where the buttons are as it is a little harder to pry off.
      • If the back casing is loose from the camera body, it may be easier to perform step 4 first, then accomplish this step. Proceed as your unit allows.
      Спросите у FixBot
    4. General Electric Create Jason Wu Casing Disassembly: шаг 4, изображение 1 из 3 General Electric Create Jason Wu Casing Disassembly: шаг 4, изображение 2 из 3 General Electric Create Jason Wu Casing Disassembly: шаг 4, изображение 3 из 3
      • The last part of the casing to disconnect is the back that houses the LCD screen.
      • The screen is attached by a connection ribbon. Gently pull the casing and screen away from the camera body to disconnect the casing.
      • The LCD screen is held onto the back casing by a small amount of adhesive. This may come loose during this process. Do not worry if they become separated.
      • This plug and the connection ribbon are fragile, try not to tear the connection ribbon when disconnecting.
      Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Kylan Hennessy
Участник с: 01/23/17
573 Репутация
Автор 5 руководств
Команда
Eastern Washington University, Team 2-6, Crane Winter 2017 Участник Eastern Washington University, Team 2-6, Crane Winter 2017
EWU-CRANE-W17S2G6
4 членов
Автор 63 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 4
За последние 30 дней: 22
За всё время: 584
