GoPro Hero Battery Replacement
Выберете то, что вам нужно
  1. GoPro Hero Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
    Спросите у FixBot
    Добавить комментарий
  2. GoPro Hero Battery Replacement: шаг 2, изображение 1 из 1
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
    Спросите у FixBot
  3. GoPro Hero Battery Replacement: шаг 3, изображение 1 из 1
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
    • Use a plastic spudger to pry the battery off from the white plastic piece underneath.
    • The battery is glued to the plastic so some force might be necessary.
    • Be careful not to damage the battery to avoid releasing dangerous chemicals.
    Спросите у FixBot
  4. GoPro Hero Battery Replacement: шаг 4, изображение 1 из 1
    • Remove the battery from the GoPro.
    Спросите у FixBot
Заключение
29 человек успешно провели ремонт по этому руководству.
River Drake
Участник с: 04/02/15
1 065 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 12-2, Lancaster Spring 2015 Участник Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 членов
Автор 18 руководств
20 Комментарии к руководству
The tutorial is excellent, even with a link to the tools needed, but no link to battery sale.
Could you please include this?
juliomap - Ответить Поделиться
Very good tutorial thank you. But I can also find no place to buy a new battery... But here is a petition to make Gopro sell spare parts: https://www.change.org/p/gopro-support-o...
maire - Ответить Поделиться
I followed these steps and inadvertently pulled not only the battery plug but its adapter (housing) at the same time. Now I can't plug the battery back in because there's no place to plug it! Contacting GoPro they stressed that the battery is not intended for removal.
erikwikstrom - Ответить Поделиться
Awesome! Could you also show us how to put in a new battery, how do i prep my battery? What type of a battery can i use ? Thanks a lot !!
John misquita - Ответить Поделиться
now add go pro to rice for a day and pray.
chadd23 - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 7
За последние 7 дней: 51
За последние 30 дней: 276
За всё время: 83,838
