Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Use this guide to replace the charging assembly. The charging assembly contains the USB-C port and is connected to the vibration motor.
  1. If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. This also makes a smooth surface allowing the suction cup to bond. Apply a suction cup as close to the volume button edge of the phone as you can while avoiding the curved edge.
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. This also makes a smooth surface allowing the suction cup to bond.
    • Apply a suction cup as close to the volume button edge of the phone as you can while avoiding the curved edge.
    • The suction cup will not make a good seal on the curved portion of the glass.
  2. Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case. This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener,  heat gun, or hair dryer. This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener,  heat gun, or hair dryer.
    • Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case.
    • This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener, heat gun, or hair dryer.
  3. In the following steps, extra caution is required in certain areas to avoid damage to the phone: Do not insert the pick more than 0.5 inches into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel it can damage the display.
    • In the following steps, extra caution is required in certain areas to avoid damage to the phone:
    • Do not insert the pick more than 0.5 inches into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel it can damage the display.
    • Only make very shallow cuts in the upper left corner, prying deeply can damage the front-facing camera.
  4. In the following steps, use the flat of the opening pick, rather than a corner, to cut here. This will help prevent inserting the pick too deeply. Slide the opening pick up the right side of the phone to separate the display adhesive.
    • In the following steps, use the flat of the opening pick, rather than a corner, to cut here. This will help prevent inserting the pick too deeply.
    • Slide the opening pick up the right side of the phone to separate the display adhesive.
  5. Slide the opening pick around the upper-right corner and along the top edge of the phone. Slide the opening pick around the upper-right corner and along the top edge of the phone. Slide the opening pick around the upper-right corner and along the top edge of the phone.
    • Slide the opening pick around the upper-right corner and along the top edge of the phone.
  6. Slide the pick around the upper-left corner of the phone and down the left edge of the phone. Slide the pick around the upper-left corner of the phone and down the left edge of the phone. Slide the pick around the upper-left corner of the phone and down the left edge of the phone.
    • Slide the pick around the upper-left corner of the phone and down the left edge of the phone.
  7. Slide the pick around the bottom-left corner and along the bottom of the phone. Keep pick at a slight angle away from the screen to avoid damage to the OLED corners. Slide the pick around the bottom-left corner and along the bottom of the phone. Keep pick at a slight angle away from the screen to avoid damage to the OLED corners. Slide the pick around the bottom-left corner and along the bottom of the phone. Keep pick at a slight angle away from the screen to avoid damage to the OLED corners.
    • Slide the pick around the bottom-left corner and along the bottom of the phone. Keep pick at a slight angle away from the screen to avoid damage to the OLED corners.
  8. Reinsert the pick at the top edge of the phone and gently pry up the display. If the display doesn't readily lift, do some extra prying to separate the last of the adhesive. The adhesive near the upper speaker is thicker than other places.
    • Reinsert the pick at the top edge of the phone and gently pry up the display.
    • If the display doesn't readily lift, do some extra prying to separate the last of the adhesive. The adhesive near the upper speaker is thicker than other places.
    • Don't try to fully separate the display yet, as a fragile ribbon cable still connects it to the phone's motherboard.
  9. Carefully lay the display down on top of the rear case as shown, making sure not to crease or tear the display ribbon cable. Remove the two 4.0 mm T5 Torx screws securing the display cable bracket.
    • Carefully lay the display down on top of the rear case as shown, making sure not to crease or tear the display ribbon cable.
    • Remove the two 4.0 mm T5 Torx screws securing the display cable bracket.
  10. Remove the display cable bracket.
    • Remove the display cable bracket.
  11. Use the point of a spudger to lift the display cable connector up and out of its socket on the motherboard. To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • Use the point of a spudger to lift the display cable connector up and out of its socket on the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • If any part of your screen doesn't respond to touch after your repair re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
    • During reassembly, pause here and replace the adhesive around the edges of the display.
  12. Apply a heated iOpener to the proximity sensor on the top edge of the midframe for two minutes to soften its adhesive.
    • Apply a heated iOpener to the proximity sensor on the top edge of the midframe for two minutes to soften its adhesive.
  13. Slide the point of a spudger under the proximity sensor cable, starting from the side closest to the front-facing camera. Gently lift the edge of the sensor cable until the sensor is perpendicular to the midframe.
    • Slide the point of a spudger under the proximity sensor cable, starting from the side closest to the front-facing camera.
    • Gently lift the edge of the sensor cable until the sensor is perpendicular to the midframe.
  14. Peel back the small piece of tape covering the screw below the earpiece speaker.
    • Peel back the small piece of tape covering the screw below the earpiece speaker.
    • Remove the following screws securing the midframe:
    • Eleven 3.7 mm Phillips screws
    • One 4 mm T5 Torx screw
  15. Insert an opening tool into the notch in the midframe near the hold button. Pry the midframe up enough to create a gap between it and the phone case. The midframe cannot yet be completely removed.
    • Insert an opening tool into the notch in the midframe near the hold button.
    • Pry the midframe up enough to create a gap between it and the phone case. The midframe cannot yet be completely removed.
  16. Lift the midframe up starting from the bottom edge. When the midframe starts to make about a 45° with the rest of the phone, lift the midframe straight up and away from the phone. As you lift the midfame, carefully guide the proximity sensor through the small slot in the midframe.
    • Lift the midframe up starting from the bottom edge.
    • When the midframe starts to make about a 45° with the rest of the phone, lift the midframe straight up and away from the phone.
    • As you lift the midfame, carefully guide the proximity sensor through the small slot in the midframe.
  17. Use the flat end of a spudger to disconnect the battery connector. Use the flat end of a spudger to disconnect the battery connector.
    • Use the flat end of a spudger to disconnect the battery connector.
  18. Use the flat end of a spudger to disconnect the charging assembly connector. Use the flat end of a spudger to disconnect the charging assembly connector.
    • Use the flat end of a spudger to disconnect the charging assembly connector.
  19. Use the point of a spudger to pry the white antenna cable connector straight up and disconnect it from the charging assembly board. Use the point of a spudger to pry the white antenna cable connector straight up and disconnect it from the charging assembly board.
    • Use the point of a spudger to pry the white antenna cable connector straight up and disconnect it from the charging assembly board.
  20. Use tweezers to pull the white antenna cable straight up and out of the metal clips on the board and out of the channel on the loudspeaker.
    • Use tweezers to pull the white antenna cable straight up and out of the metal clips on the board and out of the channel on the loudspeaker.
    • Move the cable to the left of the phone to keep it out of the way of the loudspeaker.
  21. Use the tip of a spudger pry the black antenna cable connector straight up and disconnect it. Use the tip of a spudger pry the black antenna cable connector straight up and disconnect it.
    • Use the tip of a spudger pry the black antenna cable connector straight up and disconnect it.
  22. Use tweezers to lift the black antenna cable out of its channel on the loudspeaker.
    • Use tweezers to lift the black antenna cable out of its channel on the loudspeaker.
    • Move the cable toward the top of the phone to keep it out of the way of the loudspeaker.
  23. Use the tip of a spudger to gently push the speaker cable connector out of its socket, alternating pushing either side of the connector out a little bit at a time. Use the tip of a spudger to gently push the speaker cable connector out of its socket, alternating pushing either side of the connector out a little bit at a time. Use the tip of a spudger to gently push the speaker cable connector out of its socket, alternating pushing either side of the connector out a little bit at a time.
    • Use the tip of a spudger to gently push the speaker cable connector out of its socket, alternating pushing either side of the connector out a little bit at a time.
  24. Use an opening tool to pry the loudspeaker assembly up slightly from its recess in the phone. Hold the silver charging assembly cable out of the way while you're working, but be careful not to bend it too far or apply too much strain where it connects to the charging assembly.
    • Use an opening tool to pry the loudspeaker assembly up slightly from its recess in the phone.
    • Hold the silver charging assembly cable out of the way while you're working, but be careful not to bend it too far or apply too much strain where it connects to the charging assembly.
  25. Rotate the top right corner of the loudspeaker toward the top of the phone while sliding the whole assembly to the right. Remove the loudspeaker. Remove the loudspeaker.
    • Rotate the top right corner of the loudspeaker toward the top of the phone while sliding the whole assembly to the right.
    • Remove the loudspeaker.
  26. Remove one 2.4 mm Phillips screw.
    • Remove one 2.4 mm Phillips screw.
  27. Use an opening tool the gently lift the vibration motor and separate it from the adhesive holding it to the phone. Do not try to remove the motor—it's still attached to the charging assembly.
    • Use an opening tool the gently lift the vibration motor and separate it from the adhesive holding it to the phone.
    • Do not try to remove the motor—it's still attached to the charging assembly.
  28. Use the point of a spudger to lift the top of the charging assembly away from the phone. Do not completely remove the charging assembly yet. It is still attached to the vibration motor.
    • Use the point of a spudger to lift the top of the charging assembly away from the phone.
    • Do not completely remove the charging assembly yet. It is still attached to the vibration motor.
  29. Make sure the vibration motor is not adhered to the phone, then gently lift the charging assembly out of the the phone, lifting the motor out at the same time.
    • Make sure the vibration motor is not adhered to the phone, then gently lift the charging assembly out of the the phone, lifting the motor out at the same time.
    • If you wish to remove the vibration motor, you have to desolder its wires from the charging assembly board.
Заключение
7 участников успешно повторили данное руководство.
Adam O'Camb
Участник с: 11.04.2015
72 206 Репутация
Автор 171 руководств
Команда
iFixit Участник iFixit
Community
108 членов
Автор 9 943 руководств
Один комментарий
I’m fairly disappointed with this. It didn’t say that the microphone chip had to be transferred to a new part. This caused me to take this phone apart twice.
fatkidadventure - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 15
За последние 7 дней: 138
За последние 30 дней: 682
За всё время: 9,728
