Введение
This guide will outline how to replace the power button should it be non responsive or faulty.
Выберете то, что вам нужно
Use a heat gun to melt the adhesive that holds the screen to the device
Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
Инструмент, используемый на этом этапе:Tweezers$4.99
Follow the same removal procedure to detach the wide gold cable.
Locate and remove the black 4.3mm Phillips #000 screw.
Remove the remaining two silver 4.2mm Phillips #000 screws.
Use tweezers to slowly pull up on the power button technology as far as possible without pulling out the two black wires attached.
Detach the larger connector wire by flipping the copper hinge located at the base of the connection with your fingernail.
Locate and remove the three 4.2mm Phillips #000 screws at the base of where the second wire is still connected.
Once all the screws are removed, gently pull up on the entire power button technology piece, to remove it from the device.
To reassemble your device, follow these instructions in reverse order. New adhesive will be needed to re-apply the screen.
Еще один человек закончил это руководство.
1 Комментарий к руководству
I have replaced the power/volume button flex with these instructions with a reportably working item, but power button still doesn't work. The volume buttons work just fine. Any other ideas about what might be the problem?
