Google Pixel C Screen Replacement
Выберете то, что вам нужно
    1. Google Pixel C Screen Replacement, Screen: шаг 1, изображение 1 из 1
      • Ensure that the device is completely powered down before beginning to take it apart
      • Use a heat gun to melt the adhesive that holds the screen to the device
      • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
      • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
      Спросите у FixBot
      Добавить комментарий
    2. Google Pixel C Screen Replacement: шаг 2, изображение 1 из 2 Google Pixel C Screen Replacement: шаг 2, изображение 2 из 2
      • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
      • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
      • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
      • Reattaching the screen will require adhesive to ensure that it stays in place.
      Спросите у FixBot
    3. Google Pixel C Screen Replacement: шаг 3, изображение 1 из 2 Google Pixel C Screen Replacement: шаг 3, изображение 2 из 2
      • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
      Спросите у FixBot
    4. Google Pixel C Screen Replacement: шаг 4, изображение 1 из 2 Google Pixel C Screen Replacement: шаг 4, изображение 2 из 2
      Инструмент, используемый на этом этапе:
      • Follow the same removal procedure to detach the wide gold cable.
      • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
      • This device is missing a battery, so the device that you are working on may appear slightly different inside.
      Спросите у FixBot
Заключение
9 человек успешно провели ремонт по этому руководству.
Deborah Iwakiri
Участник с: 04/25/17
522 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S21-G4, Livingston Spring 2017 Участник Cal Poly, Team S21-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G4
4 членов
Автор 11 руководств
28 Комментарии к руководству
Where can a replacement screen be located?
Ronnie Williams - Ответить Поделиться
Where can i buy a spare screen for this tablet?
Luigi Abbinante - Ответить Поделиться
Yes, I have to buy the screen too, but where??
Кирилл Кнышев - Ответить Поделиться
All very nice but unfortunately useless without knowing where to get the parts :(
Lorenzo Braschi - Ответить Поделиться
Ciao Lorenzo, sei poi riuscito a trovare il ricambio?
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 18
За последние 30 дней: 86
За всё время: 19,633
