Google Pixel C Speaker Replacement
Выберете то, что вам нужно
    1. Google Pixel C Speaker Replacement, Screen: шаг 1, изображение 1 из 1
      • Ensure that the device is completely powered down before beginning to take it apart
      • Use a heat gun to melt the adhesive that holds the screen to the device
      • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
      • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
      Спросите у FixBot
      Добавить комментарий
    2. Google Pixel C Speaker Replacement: шаг 2, изображение 1 из 2 Google Pixel C Speaker Replacement: шаг 2, изображение 2 из 2
      • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
      • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
      • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
      • Reattaching the screen will require adhesive to ensure that it stays in place.
      Спросите у FixBot
    3. Google Pixel C Speaker Replacement: шаг 3, изображение 1 из 2 Google Pixel C Speaker Replacement: шаг 3, изображение 2 из 2
      • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
      Спросите у FixBot
    4. Google Pixel C Speaker Replacement: шаг 4, изображение 1 из 2 Google Pixel C Speaker Replacement: шаг 4, изображение 2 из 2
      Инструмент, используемый на этом этапе:
      • Follow the same removal procedure to detach the wide gold cable.
      • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
      • This device is missing a battery, so the device that you are working on may appear slightly different inside.
      Спросите у FixBot
    1. Google Pixel C Speaker Replacement, Speaker: шаг 5, изображение 1 из 1
      • Locate the thin black speakers along the right and left sides of the tablet.
      • The longer speaker is secured by two different types of screws, while the shorter one is secured by two of the same type of screw.
      Спросите у FixBot
    2. Google Pixel C Speaker Replacement: шаг 6, изображение 1 из 1
      • Use the Phillips #000 screwdriver to remove the three 4.2mm screws
      • Use the same screwdriver to remove the 2.5mm screw as well.
      Спросите у FixBot
    3. Google Pixel C Speaker Replacement: шаг 7, изображение 1 из 3 Google Pixel C Speaker Replacement: шаг 7, изображение 2 из 3 Google Pixel C Speaker Replacement: шаг 7, изображение 3 из 3
      • Locate the two circular metal caps that are attached to the short speaker via a small cable and gently pull them out of the device
      • Locate and detach the third cable cap that is attached to the longer speaker.
      • The third cable runs along the upper edge of the device, and is secured down with adhesive.
      Спросите у FixBot
    4. Google Pixel C Speaker Replacement: шаг 8, изображение 1 из 1
      • Slide both speakers out from the edges of the device.
      Спросите у FixBot
    5. Google Pixel C Speaker Replacement: шаг 9, изображение 1 из 3 Google Pixel C Speaker Replacement: шаг 9, изображение 2 из 3 Google Pixel C Speaker Replacement: шаг 9, изображение 3 из 3
      • Locate the red and black twisted wires.
      • Use a spudger to pry under the cable and pop it free from the attachment, fully detaching the speaker from the device.
      Спросите у FixBot
Заключение
Isabelle Tang
Участник с: 04/26/17
225 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S21-G4, Livingston Spring 2017 Участник Cal Poly, Team S21-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G4
4 членов
Автор 11 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 37
За всё время: 1,271
