Введение
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
This guide shows how to remove and replace Google Pixel XL's display assembly, which includes the screen and digitizer.
The Pixel XL’s unreinforced display panel is fragile and is attached to the frame with strong adhesive, making repairs difficult. There is a considerable chance of breaking the display, especially if it already has micro-fractures. Be sure to apply plenty of heat and be extremely careful during the prying stage.
Выберете то, что вам нужно
Heat an iOpener and apply it to the top edge of the display for two minutes.
Take note of the following regions before you begin prying:
Thin adhesive lined against the display panel
Thick adhesive
The OLED display panel, which is very prone to damage
The display cable, which can be damaged during prying
Once the edge is warm to the touch, apply a suction cup close to the edge.
Lift on the suction cup, and insert an opening pick into the gap.
If you have trouble creating a gap, reheat the edge and try again.
Slide the opening clip across the top edge to slice through the adhesive.
Leave an opening pick in the edge to prevent the adhesive from resealing.
Heat an iOpener and apply it to the right edge of the phone for two minutes.
Insert an opening pick near the top edge of the phone, where you have already sliced the adhesive.
Slowly guide the pick around the right corner.
Carefully slide the pick down the right edge of the phone to slice through the adhesive.
Repeat the step for the left edge of the phone.
Heat the bottom edge with an iOpener for two minutes.
Insert a pick near the right edge where you have already loosened the adhesive.
Carefully guide the pick around the corner.
Slide the pick along the bottom edge to slice through the adhesive.
Once you have sliced around the perimeter of the phone, carefully lift the display assembly up slightly by the right corners.
Use an opening pick to slice through any remaining adhesive.
Lift the display assembly from the top end and swing it around such that it rests upside down on the frame.
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Remove the two 4 mm T5 screws securing the display cable bracket.
Remove the display cable bracket.
Use the point of a spudger to pry up and disconnect the display cable from its connector.
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
If your Pixel won't turn on after replacing the screen, there is a chance that the phone has silently turned on when the battery is re-connected. Hold the power button for a few seconds until the phone vibrates off. Afterwards, re-connect the screen, and try again.
Repair didn’t go as planned? Check out our Google Pixel XL Answers community for troubleshooting help.
33 участников успешно повторили данное руководство.
11 Комментариев
I just connected the screen to the phone, but the screen doesn’t start. Do I have to restart in a special way the phone to make it works? All possible button combinations to restart the phone doesn’t work
The iFixIt iOpener tool is a complete waste of money. It didn’t loosen up the glue at all. I am requesting a refund on Amazon.com
Hi Drew, sorry to hear that your iOpener didn’t work too well in your repairs. We like to think it’s a pretty valuable and inexpensive tool, but it does have its quirks — namely, not everyone’s microwave is specced to operate at the same temperatures, so not everyone will achieve the most optimal temperature during that heating process.
For what it’s worth, we do put a Lifetime Warranty on the iOpener tools, so our Support team would be happy to replace that one for you, if you’d like. If so, please reach out to them by using the Contact link on the help page: http://help.ifixit.com. Otherwise, you are welcome to request a refund via Amazon and we will oblige.
We wish you all the best in your future repairs.
I am sure the iOpener does work, but it probably takes a long time to heat the adhesive enough for screen removal and would require several applications. I got one as part of my screen replacement kit, although I have a heat gun so I didn’t end up using it. That being said my screen took at least four minutes of heating, with some re-heating to remove the broken shards. I would also imagine that adhesives vary from manufacturer, since this is my first screen replacement all I know is that the adhesive on the Pixel XL is really strong!
Dan E -
Don’t forget to transfer the speaker cloth to the new screen. I got it all back together before realizing that there was just an ugly hole.
