Guitar String Replacement
Выберете то, что вам нужно
  1. Guitar String Replacement, Loosen the tuning pegs: шаг 1, изображение 1 из 1
    • Turn the tuning pegs counter clock-wise to loosen all of the guitar strings and release the tension.
    Спросите у FixBot
    Добавить комментарий
  2. Guitar String Replacement, Remove old guitar strings: шаг 2, изображение 1 из 1
    • Cutting a string under tension could cause injury. Ensure that all strings are loose before attempting the next step.
    • Once the strings are loose and have no tension, cut the strings with a handheld wire cutter.
    • Cut the knots near the tuning pegs and bridge as needed. Then, pull the strings to remove them.
    Спросите у FixBot
  3. Guitar String Replacement, Thread strings through the bridge: шаг 3, изображение 1 из 3 Guitar String Replacement, Thread strings through the bridge: шаг 3, изображение 2 из 3 Guitar String Replacement, Thread strings through the bridge: шаг 3, изображение 3 из 3
    • The first three strings (low E, A, and D), have thick and springy ends; the three thinnest strings (G, B, and high E), do not have thick or springy ends. You may use either set of strings.
    • Insert the thick end of the string into the top of the bridge and thread it through until about 3 to 4 inches of the string stick out of the bottom.
    • Wrap the short end of the string around the long end of the string, creating a loop.
    • Pass the short end of the string through the loop (2 or 3 times for thick strings, 3 or 4 times for thin strings). Make sure the final pass leaves the string underneath the bridge.
    • Pull both ends of the string until the knot is tight.
    Спросите у FixBot
  4. Guitar String Replacement, Knot the low E, G, and B strings: шаг 4, изображение 1 из 3 Guitar String Replacement, Knot the low E, G, and B strings: шаг 4, изображение 2 из 3 Guitar String Replacement, Knot the low E, G, and B strings: шаг 4, изображение 3 из 3
    • This knot will be used for only the low E, G, and B strings.
    • Insert the springy end of the string into the hole in the tuning peg.
    • Pull the springy end over the tuning peg and to the left side.
    • Bring the springy end to the right side by passing it under the string, creating a loop.
    • Push the springy end through the loop, and then pull both ends until the knot is tight. You may have to press the knot with your finger tighten it completely.
    Спросите у FixBot
  5. Guitar String Replacement, Knot the A, D, and high E strings: шаг 5, изображение 1 из 3 Guitar String Replacement, Knot the A, D, and high E strings: шаг 5, изображение 2 из 3 Guitar String Replacement, Knot the A, D, and high E strings: шаг 5, изображение 3 из 3
    • Repeat step 4 (outlined below) for only the strings A, D, and high E .
    • Insert the end of the string into the hole in the tuning peg.
    • Pull the end over the tuning peg to the right side.
    • Bring the end of the string to the left side by passing it under the string, creating a loop.
    • Push the end through the loop and then pull both ends until the knot is tight. You may have to press and hold the knot with your finger to tighten completely.
    Спросите у FixBot
  6. Guitar String Replacement, Tighten the new strings: шаг 6, изображение 1 из 3 Guitar String Replacement, Tighten the new strings: шаг 6, изображение 2 из 3 Guitar String Replacement, Tighten the new strings: шаг 6, изображение 3 из 3
    • Turn the tuning knob in a clock-wise motion to tighten the string until the string makes a clear sound when plucked.
    • As you tighten the string, be sure to hold the string with your free hand until the string stays tight on its own. This will keep the knot from loosening.
    • As the string winds around the tuning peg, make sure that the string passes over the loose end from the knot at least once. This will prevent "slipping" (detuning) during tuning and will help keep the knot tight.
    Спросите у FixBot
  7. Guitar String Replacement, Check your work before tuning: шаг 7, изображение 1 из 1
    • Before moving on, compare your work to the image provided. If the head of your guitar does not resemble the guitar in the image, go back to steps 3 and 4.
    • The E strings should be facing outwards (or "away from the body") and the rest of the strings should be facing inwards (or "toward the body").
    • Check that strings are properly set in the notches of the nut of the guitar. The "nut" is the white bar just below the head of the guitar.
    • You are ready to tune your guitar! Classical guitar strings may "slip" or detune. It may take 4 or more rounds of tuning before the new strings stop slipping.
    Спросите у FixBot
  8. Guitar String Replacement, Clip the loose ends: шаг 8, изображение 1 из 3 Guitar String Replacement, Clip the loose ends: шаг 8, изображение 2 из 3 Guitar String Replacement, Clip the loose ends: шаг 8, изображение 3 из 3
    • Once you have tuned your guitar, remove the loose ends of the strings from the head and bridge of the guitar with your handheld wire cutter.
    • Do not completely remove the loose ends. Cutting the end too close to the tuning peg or the bridge may cause the string to slip out of position later. Leave at least a half inch piece in place.
    Спросите у FixBot
Заключение
Your new strings are now in place!
Еще один человек закончил это руководство.
Nicholas Mullins
Участник с: 01/19/16
129 Репутация
1 руководство автора
Команда
Oakland University, Team 6-1, Walwema Winter 2016 Участник Oakland University, Team 6-1, Walwema Winter 2016
OAK-WALWEMA-W16S6G1
10 членов
Автор 34 руководств
1 Комментарий к руководству
what do I pay? very good site haven't played in a while usually at church
davenport - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 28
За последние 30 дней: 112
За всё время: 10,558
