Введение
If there is broken piece of the HMDX Chill rubber base this can result in the speaker not standing properly and thus distorting the sound. This guide will show how to locate and replace the rubber base in order to assure the best sound quality possible from the HMDX Chill.
Выберете то, что вам нужно
Insert a metal spudger under the rubber base.
Pry the rubber base off.
Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
