HP 15-ay052nr Fan Replacement
Выберете то, что вам нужно
    1. HP 15-ay052nr Fan Replacement, Battery: шаг 1, изображение 1 из 1
      • To protect the device and yourself, make sure your device is completely powered down before disassembling. Disconnect all external devices before starting any tear down process.
      • Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
      Спросите у FixBot
      Добавить комментарий
    2. HP 15-ay052nr Fan Replacement: шаг 2, изображение 1 из 1
      • Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
      • The sliders are located at the back of the device on the side where the display hinges are.
      • The slider closest to the optical drive (CD reader) clicks open but the opposite slider has a spring.
      Спросите у FixBot
    3. HP 15-ay052nr Fan Replacement: шаг 3, изображение 1 из 1
      • Pull the battery slightly up and out to remove.
      • If the battery doesn't pop out, the sliders weren't pushed in far enough. Push the sliders towards the center until the battery pops out.
      Спросите у FixBot
    1. HP 15-ay052nr Fan Replacement, Bottom Cover: шаг 4, изображение 1 из 1
      • Remove the rubber feet on the bottom of the device to access all the screws.
      • There are two rubber feet, one on each side of the battery compartment.
      Спросите у FixBot
    2. HP 15-ay052nr Fan Replacement: шаг 5, изображение 1 из 1
      • Unscrew the twelve 9 mm JIS #0 screws on the back of the device.
      • Gently remove the optical drive (CD reader) to more easily separate the base.
      Спросите у FixBot
    3. HP 15-ay052nr Fan Replacement: шаг 6, изображение 1 из 1
      • Unclip the keyboard surface from the base using an iFixit opening tool around the entire border.
      Спросите у FixBot
    4. HP 15-ay052nr Fan Replacement: шаг 7, изображение 1 из 1
      • Separate the base of the computer from the component assembly.
      • The optical drive can be placed in the base where it corresponds to prevent misplacing it.
      Спросите у FixBot
    1. HP 15-ay052nr Fan Replacement, Fan: шаг 8, изображение 1 из 1
      • Remove the two 6.5 mm JIS #0 screws holding the cooling fan to the base.
      • The base is the side by the heatsink, which is made of copper.
      Спросите у FixBot
    2. HP 15-ay052nr Fan Replacement: шаг 9, изображение 1 из 1
      • Unplug the fan cable from the motherboard.
      • The fan can now be removed.
      Спросите у FixBot
Заключение
Stephanie Harms
Участник с: 01/13/19
97 Репутация
1 руководство автора
Команда
Oregon Institute of Technology, Team S1-G5, Lancaster Winter 2019 Участник Oregon Institute of Technology, Team S1-G5, Lancaster Winter 2019
OIT-LANCASTER-W19S1G5
4 членов
Автор 71 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 22
За всё время: 773
