Введение
If your device is over heating excessively, and running loudly, the fan may need to be replaced. Follow this guide to correctly remove it.
Выберете то, что вам нужно
Using a Phillips #000 screwdriver, remove the eleven 10 mm screws located on the underside of the laptop, that are holding the back panel in place.
Using a Phillips #000 screwdriver remove the 5mm screw holding the fan in place.
After the screw is removed, carefully unplug the set of wires with one of each colored, red, black, yellow, and blue, from the white connector it is secured at.
