Введение
This guide will require removal of 3x5mm screws (on motherboard) and 1x3mm screws (on sensor board).
Выберете то, что вам нужно
Flip the laptop so the base of the laptop is facing you.
Using the #00 screwdriver, unscrew the 13 screws.
Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
Lift the white flap and pull the blue ribbon towards you until it is disconnected.
Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
Undo the black tape located on the bottom from the frame of the laptop.
Using fingers or the spudger, slide out the black connector indicated on the left.
Use a #00 screwdriver to remove the two screws.
Lift the black flaps and gently pull the strip out.
Set the strip aside.
Remove the screw.
Use your fingers to pull the white tab out of the black slot above the battery.
Using a spudger, remove the white and black cables from the card.
Remove the 3 screws around the fan.
Using your fingers or the spudger, disconnect the cable connecting the fan to the motherboard.
Once the cable connecting the fan to the motherboard is revomed gently remove fan with hands.
Remove all of the indicated screws.
Pull up on black strip to remove the monitor cord.
2 человек успешно провели ремонт по этому руководству.
4 Комментарии к руководству
Can someone just explain for what the sensor board is needed?
Let's the motherboard know when the lid is closed.
Hi! How do you start a chrome book from motherboard? Since I am doing a project I need help with that question.... Please send a mail with the explanation on my mail: steffe010929@gmail.con
hope some one is still maintaining this site, i would like to know if i would be able to use a motherboard from another HP chromebook in the same product line for example if i have a motherboard from the 14-q010dx can i swap it with the motherboard from the 14-q010nr? thevet82@gmail.com
