Введение
In this guide, we will illustrate how to remove and replace the hard drive for this device. Tools required include thumbs and a Phillips screwdriver.
Выберете то, что вам нужно
Loosen the two 1.5 cm Phillips #1 screws that attach the cover of the hard drive .
Lift up the cover.
Loosen the 1.5 cm Phillips #1 screw attaching the hard drive to the laptop.
Locate the tab on the hard drive.
Use this tab to pull the hard drive toward the right side of the case.
Remove the hard drive.
Еще один человек закончил это руководство.
1 Комментарий к руководству
Good info we are getting here. keep up!
