Введение
To remove the fan, first the keyboard must be removed as well as other components such as the display.
Выберете то, что вам нужно
Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
Turn the laptop over so that you see the bottom.
Locate the twenty 3 mm Phillips head screws.
Unscrew them using the PH0 screwdriver
After unscrewing the 3 mm screws, remove the hard drive covering by lifting upward.
Unhook the two wires connecting to the wireless card by gently pulling them out.
Инструмент, используемый на этом этапе:Tweezers$4.99
Locate the power button connector wire. (This can be found where the keyboard sits.)
Using the tweezers, unhook the wire.
Press and hold the lock to pop the panel piece above the keyboard and pull up to remove it.
Locate the four 3 mm Phillips head screws.
Unscrew them using the PH0 screwdriver.
Locate the disk drive on the side of the device.
Remove it by pulling it all the way out.
Use the PH0 screwdriver to remove the two 3 mm Phillips head screws in the disk drive port.
Еще один человек закончил это руководство.
