HP Compaq nc8430 Fan Replacement
Выберете то, что вам нужно
    1. HP Compaq nc8430 Fan Replacement, Battery: шаг 1, изображение 1 из 1
      • Completely shut down the device and unplug any adapters and cords connected to the device.
      • Carefully flip the device over so that the bottom is facing up.
      • Slide both of the latches to the left.
      Спросите у FixBot
      Добавить комментарий
    2. HP Compaq nc8430 Fan Replacement: шаг 2, изображение 1 из 1
      • Slide up against the three lines the battery has.
      Спросите у FixBot
    3. HP Compaq nc8430 Fan Replacement: шаг 3, изображение 1 из 1
      • Slide the battery up and away from the laptop.
      • Slowly remove the battery to prevent any connectors from getting damaged.
      Спросите у FixBot
    1. HP Compaq nc8430 Fan Replacement, Fan: шаг 4, изображение 1 из 1
      • Use a J1 screwdriver to remove each screw on the bottom of the computer. This will allow for the opening of the laptop to gain access to the fan.
      Спросите у FixBot
    2. HP Compaq nc8430 Fan Replacement: шаг 5, изображение 1 из 1
      • Now that you have unscrewed most of the bottom of the laptop, carefully flip it back over.
      • Press down firmly on the four latches shown in the photo to detach the key board. This will unlock the latches holding the keyboard down, doing this will grant you access to the inside of the computer.
      Спросите у FixBot
    3. HP Compaq nc8430 Fan Replacement: шаг 6, изображение 1 из 2 HP Compaq nc8430 Fan Replacement: шаг 6, изображение 2 из 2
      • Remove the keyboard carefully now that it is detached, and use the pry tool to assist you in the removal of the keyboard.
      Спросите у FixBot
    4. HP Compaq nc8430 Fan Replacement: шаг 7, изображение 1 из 1
      • Now your laptop should have no screws and no keyboard.
      • You should now be able to open up the base of the laptop. With a bit of force, detach the sides latches of the base by pulling them open carefully.
      • Your computer should now look like the provided photo, where you can see where the fan is located.
      Спросите у FixBot
    5. HP Compaq nc8430 Fan Replacement: шаг 8, изображение 1 из 2 HP Compaq nc8430 Fan Replacement: шаг 8, изображение 2 из 2
      • Carefully remove fan by detaching the blue and white plug from the main socket.
      • Continue to unscrew all screws to completely disassemble to gain complete access to the computer's fan.
      Спросите у FixBot
    6. HP Compaq nc8430 Fan Replacement: шаг 9, изображение 1 из 1
      • As an extra precaution, please check for any dirt or debris that are preventing the fans complete functionality.
      • Use a cotton swab and alcohol to clean the fan before re attaching it to ensure smooth functioning of the fan.
      Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Andrea Funes
Участник с: 03/22/17
149 Репутация
1 руководство автора
Команда
Texas Tech, Team S13-G4, Bennett Spring 2017 Участник Texas Tech, Team S13-G4, Bennett Spring 2017
TTU-BENNETT-S17S13G4
5 членов
Автор 11 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 20
За всё время: 1,680
