HP Envy m6 1220sb Disassembly
Выберете то, что вам нужно
    1. HP Envy m6 1220sb Disassembly, HP Envy m6 1220sb Disassembly: шаг 1, изображение 1 из 2 HP Envy m6 1220sb Disassembly, HP Envy m6 1220sb Disassembly: шаг 1, изображение 2 из 2
      • first of all we are going to remove the bottom plastic plates and the battery
      • I apologize for the bad light ( and my Englisch , my native language is dutch), i made this guide during night..
      • after removing the battery and plates you will see the HDD, wifi m-sata module and RAM. You will also see the bios battery ( next to the HDD).
      • like always i advise you to make a map/plan of the laptop. where the screws were attached , where connectors are attached.. etc. I tape my screws to the map i draw. You can also use the magnetic project map here on ifixit.
      • Be very carefull removing the HDD connector it is not that strong
      Спросите у FixBot
      Добавить комментарий
    2. HP Envy m6 1220sb Disassembly, removing the HDD: шаг 2, изображение 1 из 2 HP Envy m6 1220sb Disassembly, removing the HDD: шаг 2, изображение 2 из 2
      • now remove the hdd by loosen the connector.
      • Be VERY gently with the connector. Use IC pliers to loose the connector.
      • mine was already broken when i bought the laptop.
      • after you removed the connector, lift the hdd to one side and pull ( gently) it out.
      • also remove the connector ( flex cable) attached to the mainboard. see green circle in second picture.
      • to loosen this connector use a spudger to lift the lid (lid of connector.) up. do it very gently.
      Спросите у FixBot
    3. HP Envy m6 1220sb Disassembly, remove RAM and Wifi: шаг 3, изображение 1 из 1
      • now remove the RAM modules
      • remove the two antenna's ( white and black) en remove the screw of the m-sata module. the module will come towards you when you remove the screw. the antenna's are in the green circle and the screw is in the red circle.
      Спросите у FixBot
    4. HP Envy m6 1220sb Disassembly, mainboard screws: шаг 4, изображение 1 из 1
      • remove the 2 screws from the mainboard and the usb module.
      Спросите у FixBot
    5. HP Envy m6 1220sb Disassembly, removing the screws..: шаг 5, изображение 1 из 2 HP Envy m6 1220sb Disassembly, removing the screws..: шаг 5, изображение 2 из 2
      • now we will remove the screws of the case...
      • remove the screws in the red circles.
      • remove the screw in the blue circle , this is the screw from the dvd bay. You can remove this by using a metal spudger or a isesamo iopener.
      Спросите у FixBot
    6. HP Envy m6 1220sb Disassembly, remove screws keyboard: шаг 6, изображение 1 из 1
      • now we remove the screws from the keyboard.
      Спросите у FixBot
    7. HP Envy m6 1220sb Disassembly, ssd place and DC connector: шаг 7, изображение 1 из 1
      • in the orange sqaure you'll see the place to put an SSD in. (m-sata)
      • in the red circle you'll see the connector of the DC jack.
      • if you remove the DC jack do this with an IC pliers.
      Спросите у FixBot
    8. HP Envy m6 1220sb Disassembly, Removing keyboard: шаг 8, изображение 1 из 2 HP Envy m6 1220sb Disassembly, Removing keyboard: шаг 8, изображение 2 из 2
      • turn the laptop arround so you can open the lid.
      • use a screwdriver or a spudger to push the little black "fingers" from the keyboard away from the case. If you do it right you'll hear clicks.
      • afterwards, lift the keyboard up and remove it from the mainboard connector. (lift up the little black lid (gently) en pull out the cable.)
      Спросите у FixBot
    9. HP Envy m6 1220sb Disassembly, getting closer..: шаг 9, изображение 1 из 3 HP Envy m6 1220sb Disassembly, getting closer..: шаг 9, изображение 2 из 3 HP Envy m6 1220sb Disassembly, getting closer..: шаг 9, изображение 3 из 3
      • after removing the keyboard you'll see the metal case with screws and connectors. again : be very gently with removing cables from connectors. especially if its your first repair..
      • picture 1 : red circle : connector remove it by gently pulling the little lid up and pull out the cable.
      • picture 2 :red circle : screw, remove it. Orange circle : audio connector , remove it with IC pliers. Lime circle : connector , remove like others. Blue circle: connector remove like others.
      • picture 3 : Green circle : audio, remove with IC pliers. Orange circle: power FAN connector , remove with IC pliers, Lime circle : power board connector , remove it very gently. Red circle : remove screw
      • there was one other screw at the metal case, it's at the right side just above the dvd bay player. I don't have a picture..
      Спросите у FixBot
    10. HP Envy m6 1220sb Disassembly, opening the laptop: шаг 10, изображение 1 из 3 HP Envy m6 1220sb Disassembly, opening the laptop: шаг 10, изображение 2 из 3 HP Envy m6 1220sb Disassembly, opening the laptop: шаг 10, изображение 3 из 3
      • use a isesamo opener or a spudger to open the case .
      • slide your tool against the case , you will hear clicks.
      • gently remove the upper plate. afterwards you will se the mainboard.
      Спросите у FixBot
    11. HP Envy m6 1220sb Disassembly, mainboard/ screen connector: шаг 11, изображение 1 из 2 HP Envy m6 1220sb Disassembly, mainboard/ screen connector: шаг 11, изображение 2 из 2
      • remove the screen connector. be very very gently.. pull the black flap ( in the lime square ) towards you .
      • red circle : screw from mainboard.
      Спросите у FixBot
    12. HP Envy m6 1220sb Disassembly, mainboard connector to dvd: шаг 12, изображение 1 из 1
      • remove the connector. this is the connector from the sata connector dvd player bay.
      • It is possible to replace the dvd bay with a HDD bay.
      Спросите у FixBot
    13. HP Envy m6 1220sb Disassembly, removing the fan: шаг 13, изображение 1 из 2 HP Envy m6 1220sb Disassembly, removing the fan: шаг 13, изображение 2 из 2
      • remove the big screw you see in picture 1
      • we can remove the fan for taking out the mainboard or to clean the fan, or replace the fan.
      Спросите у FixBot
    14. HP Envy m6 1220sb Disassembly, removing the mainboard: шаг 14, изображение 1 из 3 HP Envy m6 1220sb Disassembly, removing the mainboard: шаг 14, изображение 2 из 3 HP Envy m6 1220sb Disassembly, removing the mainboard: шаг 14, изображение 3 из 3
      • we will remove the mainboard in different steps.
      • first remove the screw(s) of the mainboard. i had only one screw left , the others were disapeared. the first owner tried to repair the laptop.. but we know now that it has not turned out well..
      • now we will remove the usb module .. Remove the screw in the red circle, the audio cable in the orange circle and remove the screw at the green circle. This is the screw from the DC jack metal plate.
      Спросите у FixBot
    15. HP Envy m6 1220sb Disassembly, removing the mainboard part 2: шаг 15, изображение 1 из 3 HP Envy m6 1220sb Disassembly, removing the mainboard part 2: шаг 15, изображение 2 из 3 HP Envy m6 1220sb Disassembly, removing the mainboard part 2: шаг 15, изображение 3 из 3
      • lift the mainboard up and remove it from the case. the picture's are not in order so folow my explanation instead and see the picture's just as help.
      • after lifting up the mainboard tilt the motherboard so you can remove the DC connector.
      • in the second picture you see the DC connector. be very gently if you remove it ! use IC pliers.
      Спросите у FixBot
    16. HP Envy m6 1220sb Disassembly, thermal paste and cooling parts.: шаг 16, изображение 1 из 1
      • now the mainboard is free.
      • in this case you can remove the CPU cooler. ( the copper tubes) In that case remove the screws simultaneous.
      • You can add ( after cleaning the cpu and the copper with isopropyl alcohol.) some new thermal paste at the cpu and graphic chip.
      • If you add some thermal paste for the first time : be carefull ,only put a very smal drop of paste at the cpu and graphic chip.
      Спросите у FixBot
      • you can remove the screen or better sayed, replace the screen without tear down the laptop. just follow any other guide to replace a screen. normally speaking is it the same way.. thats why i didn't take pictures or guide you throuh this.
      • thanks for watching, if you have questions, cantact me and i will try to help you. or examine other guides that i wrote ( or other members) to learn about fixing laptops.
      Спросите у FixBot
Заключение
4 человек успешно провели ремонт по этому руководству.
Kevin D
Участник с: 05/02/14
7 550 Репутация
Автор 21 руководств
7 Комментарии к руководству
Hi there!
Thanks for the guide. I’m curious to repair mine, but have two questions
1) I have an envy m6 1201sg, but haven’t been able to figure out the differences between the different version numbers. Or are they actually the same?
2) How about removing the keys to clean them, is it possible?
C
leo_turtle - Ответить Поделиться
Very nice, I have same laptop Model and laptop power switch is not working. How to check whether switch is bad or not form HP ENVY m6-1125dx ?
Dinesh Singh - Ответить Поделиться
Salom menga hpni ustgi qopqogʻi kerak topiladimi
Shamsullo Quzratov - Ответить Поделиться
Iloji boʻlsa topib pochta qila olasizlarmi
Telfon nomerim +998991768069
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 9
За последние 30 дней: 63
За всё время: 17,047
