Введение
This guide will show the user how to remove the hard drive.
Выберете то, что вам нужно
Turn the device over to expose the bottom of the device.
Slide the battery release all the way to the left.
There will be a click and the battery will be released from its compartment.
Locate the two Phillips head retaining screws which secure the hard drive compartment.
Use a Phillips #0 screwdriver to loosen the retaining screws.
Remove the panel covering the compartment.
Locate the three 6 mm Phillips head screws for the hard drive.
Use a Phillips #0 screwdriver to remove the screws.
Remove the hard drive from the compartment.
Pull the connector cable from the end of the hard drive.
Locate the two 6 mm Phillips head screws on each side of the hard drive.
Remove the cover from the hard drive.
3 человек успешно провели ремонт по этому руководству.
