Введение
If the keys on your keyboard are unresponsive, you might need to replace the keyboard itself. This guide will show you the steps for replacing your HP Mini 110's keyboard.
Выберете то, что вам нужно
With the bottom of the HP Mini facing up, slide both switches inward towards each other.
With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
Remove the three 4.0 mm screws with the keyboard indicator next to them using a Phillips #1 screw driver.
Move and hold the bezel slightly towards the screen while lifting the keyboard from the top.
