Введение
This guide describes how to remove and replace the keyboard of the HP Mini 210-2070NR. This is necessary if there are hardware issues with the keyboard.
To check whether the issue is software or hardware, restarting the computer will oftentimes fix software issues; if problems persist, assume hardware issues and use this guide to replace the keyboard.
Выберете то, что вам нужно
Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
Slide the battery release latch inwards.
Pull the battery towards you to remove it.
Slide the service access cover release lever to the right.
While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
Using a 00 Phillips screwdriver, unscrew and remove the three 2.0 X 5.0 screws that connect the keyboard to the computer.
Flip the computer over so that the front is facing you.
Open the computer screen as far as possible. It should be able to lay flat on whatever surface you are working on.
Pry along the rear edge of the keyboard away from the PC with the plastic opening tool.
Once enough of an opening has been established, gently grasp the edge and pull the keyboard towards you.
Use your fingernail to flip up the black retaining flap attached to the keyboard ZIF connector.
Pull the keyboard cable out of its socket to disconnect it.
