Введение
This guide will help assist you in replacing the RAM component in your laptop. Use this guide if HP Notebook 15-ba018ds is having low storage space. Beware of all the wires that may get damaged during this process.
Выберете то, что вам нужно
Flip the laptop over so the battery is exposed which will be next to the hinges on the top left and right.
Place your thumbs on the slide locks that are next to the hinges and simultaneously push them toward each other to unlock the battery.
While still holding onto the slide locks, push the battery away from the laptop with your index fingers.
Unscrew the 8 screws on the back cover.
There are also two screws in the battery area that you unscrew.
Use an opening tool and wedge it under the edge and go around the whole laptop to help remove the back cover.
3 человек успешно провели ремонт по этому руководству.
