Введение
The RAM card is a credit card sized chip that is inserted into a specified socket located within the laptop, that is connected to the motherboard. The RAM card is designed to store memory being used at a specific time while the laptop runs a variety of programs. Usually when the computer is slow it can be due to the RAM being, old, worn out or not having enough memory storage. This guide shows how to replace the RAM card.
Выберете то, что вам нужно
Turn your laptop over so the bottom is facing up.
Locate the battery latch and slide the latch switch all the way to the left.
The RAM is inserted into its socket with some metal triggers. To remove the RAM card, push the triggers away from the RAM card.
Gently grasp the RAM card ,and pull it out.
To insert a new RAM card, put the card into the slot and press down till the metal triggers click over it, holding it in place. After that, follow steps 1 to 3 in reverse order.
