Введение
This guide provides instructions on the disassembly of the HP Pavilion tx2500 for fan replacement.
Выберете то, что вам нужно
Completely turn off and unplug device. Lay the device bottom side up on a soft surface.
Squeeze the latches on the battery until you hear a click. Slide out the battery.
Using the Phillips #0 screwdriver, remove the 4.5 mm screw from the WLAN model screen.
Once unscrewed, lift the right side of the WLAN module compartment cover and swing it to the left.
Using the plastic opening tool, disconnect the WLAN antenna cables from the WLAN module.
Using the Phillips #0 screwdriver, unscrew the 4.5 mm screw from the middle section in the battery compartment.
Flip the laptop front side up and then use your fingers to lift up the keyboard.
Lift up the black latch that connects the film strip to the base of the computer.
Use the plastic opening tool to disconnect the film strip from the base of the computer.
Rotate the screen back towards you.
Lift up the convertible hinge to unclip it from the base of the computer.
Using the Phillips #0 screwdriver, remove both of the 5.0 mm screws on the base of the rotator.
Disconnect the wire from the system board using the plastic opening tool.
Disconnect the wire from the optical drive using the plastic opening tool.
Gently lift the top cover from the tablet.
Using the plastic opening tool, disconnect the plastic blue film from the tablet.
Disconnect the wire using the plastic opening tool.
Lift the system board from the tablet.
Turn the system board over and lay it flat on a soft surface.
Using a Phillips #00, remove the 4.5 mm screws that connect the fan to the board.
Using a plastic opening tool, disconnect the wire that attached the fan to the board.
Еще один человек закончил это руководство.
