HP ProBook 4540s WLAN Module Replacement
Выберете то, что вам нужно
    1. HP ProBook 4540s WLAN Module Replacement, Battery: шаг 1, изображение 1 из 1
      • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
      • Slide the two release latches on either side of the battery.
      • Gently tilt the battery upward and remove it from its socket.
      Спросите у FixBot
      Добавить комментарий
    1. HP ProBook 4540s WLAN Module Replacement, Bottom Door: шаг 2, изображение 1 из 1
      • Turn the computer so the bottom is facing towards you.
      • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
      • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
      • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
      Спросите у FixBot
    1. HP ProBook 4540s WLAN Module Replacement, WLAN Module: шаг 3, изображение 1 из 2 HP ProBook 4540s WLAN Module Replacement, WLAN Module: шаг 3, изображение 2 из 2
      • Disconnect the antenna cables from their terminals in the WLAN module.
      • One cable is attached to the Auxiliary ("Aux") terminal, represented with a blue wire. The other cable is connected to the Main terminal which is usually represented with a red wire. These wires can be seen in little windows beside the component.
      Спросите у FixBot
    2. HP ProBook 4540s WLAN Module Replacement: шаг 4, изображение 1 из 2 HP ProBook 4540s WLAN Module Replacement: шаг 4, изображение 2 из 2
      • Unscrew two 3.0 mm Phillips PM2.0x3.0 screw securing the module to the computer.
      • The edge of the module that is opposite of the slot is risen away from the computer.
      • Gently lift and remove the module.
      Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Amber Schindler
Участник с: 10/26/16
1 144 Репутация
Автор 6 руководств
Команда
UW Tacoma, Team 1-5, Rose Fall 2016 Участник UW Tacoma, Team 1-5, Rose Fall 2016
UWT-ROSE-F16S1G5
4 членов
Автор 72 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 15
За последние 30 дней: 41
За всё время: 2,516
