HP ProBook 650 G4 Keyboard Replacement
Выберете то, что вам нужно
    1. HP ProBook 650 G4 Keyboard Replacement, Remove Back Plate: шаг 1, изображение 1 из 1
      • Loosen the 8 Philips screws circled in red in the photo. These screws are captive and should not come out fully.
      • Use pry tool starting at one of the hinges to release the clips all around the back plate
      • Remove plate and set aside.
      Спросите у FixBot
      Добавить комментарий
    2. HP ProBook 650 G4 Keyboard Replacement, Releasing Keyboard: шаг 2, изображение 1 из 3 HP ProBook 650 G4 Keyboard Replacement, Releasing Keyboard: шаг 2, изображение 2 из 3 HP ProBook 650 G4 Keyboard Replacement, Releasing Keyboard: шаг 2, изображение 3 из 3
      • Unscrew the 3 Philips screws by the keyboard icons. (Circled in red)
      • The screws are captive and should not be removed fully.
      • Open the laptop screen
      • Use keyboard removal tool to push out the keyboard (circled in green)
      • anything that fits in the hole could be used if tool not available.
      Спросите у FixBot
    3. HP ProBook 650 G4 Keyboard Replacement, Releasing keyboard: шаг 3, изображение 1 из 2 HP ProBook 650 G4 Keyboard Replacement, Releasing keyboard: шаг 3, изображение 2 из 2
      • Work around the keyboard releasing the clips.
      • Clips are only located on the top, left, and right of the keyboard.
      • flip the keyboard towards the mouse pad taking care not to damage the ribbon cables.
      Спросите у FixBot
    4. HP ProBook 650 G4 Keyboard Replacement, Release Ribbon Cables: шаг 4, изображение 1 из 3 HP ProBook 650 G4 Keyboard Replacement, Release Ribbon Cables: шаг 4, изображение 2 из 3 HP ProBook 650 G4 Keyboard Replacement, Release Ribbon Cables: шаг 4, изображение 3 из 3
      • with a plastic spudger tool flip up the black clips to release the ribbon cables
      • Gently pull out the cables, there should be no resistance if the clips were opened properly.
      • There may be some adhesive connecting the cable to the keyboard (green arrow).
      Спросите у FixBot
    5. HP ProBook 650 G4 Keyboard Replacement, Install New Ribbon Cables: шаг 5, изображение 1 из 2 HP ProBook 650 G4 Keyboard Replacement, Install New Ribbon Cables: шаг 5, изображение 2 из 2
      • Gently fold the new ribbon cables at the 15B line
      • Gently push in the ribbon cables and press down the black clips.
      • Make sure that the cables are pushed in far enough. They have a line marking how far they should be inserted.
      • Slide in the bottom clips of the keyboard and flip towards the screen
      • Push the keyboard all around until all of the clips click into place.
      Спросите у FixBot
    6. HP ProBook 650 G4 Keyboard Replacement, Reassemble Laptop: шаг 6, изображение 1 из 2 HP ProBook 650 G4 Keyboard Replacement, Reassemble Laptop: шаг 6, изображение 2 из 2
      • Screw in the 3 keyboard screws
      • Push the back plate on and screw in the 8 screws
      • Go around the back plate making sure that it is clipped in all around.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
David Salerno
Участник с: 09/14/11
823 Репутация
Автор 4 руководств
1 Комментарий к руководству
Datasheet motherboard
No power in d
evice
Mahmoud Ahmed - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 29
За последние 30 дней: 79
За всё время: 4,563
