HP Stream 11-d010nr Battery Replacement
Выберете то, что вам нужно
  1. HP Stream 11-d010nr Battery Replacement, Pry out the inserts: шаг 1, изображение 1 из 2 HP Stream 11-d010nr Battery Replacement, Pry out the inserts: шаг 1, изображение 2 из 2
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Using a spudger, gently pry off the two elliptical rubber inserts located in the top corners.
    • Carefully remove the two circular rubber inserts positioned beneath the removed elliptical inserts.
    Спросите у FixBot
    Добавить комментарий
  2. HP Stream 11-d010nr Battery Replacement, Unscrew the back cover: шаг 2, изображение 1 из 1
    • Using a Phillips #1 screwdriver, remove the eleven 5.6 mm screws securing the back cover.
    • Keep the screws in a safe place for reassembly.
    Спросите у FixBot
  3. HP Stream 11-d010nr Battery Replacement, Pry the keyboard casing up: шаг 3, изображение 1 из 2 HP Stream 11-d010nr Battery Replacement, Pry the keyboard casing up: шаг 3, изображение 2 из 2
    • Using an iFixit opening tool, carefully pry open the case to separate the keyboard from the main body. Work slowly to avoid damaging the edges.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
    Спросите у FixBot
  4. HP Stream 11-d010nr Battery Replacement, Identify the connectors: шаг 4, изображение 1 из 1
    • Carefully lift the keyboard and identify the three ribbon cables connecting the main body of the laptop to the keyboard.
    • Lift the keyboard with extreme care to avoid damaging the delicate ribbon cables. Applying excessive force can easily tear or break them easily.
    Спросите у FixBot
  5. HP Stream 11-d010nr Battery Replacement, Disconnect the cables: шаг 5, изображение 1 из 3 HP Stream 11-d010nr Battery Replacement, Disconnect the cables: шаг 5, изображение 2 из 3 HP Stream 11-d010nr Battery Replacement, Disconnect the cables: шаг 5, изображение 3 из 3
    • Using a spudger, gently lift the flaps on the ZIF connectors to release the three ribbon cables securely attached to them.
    • Carefully disconnect the three ribbon cables.
    Спросите у FixBot
  6. HP Stream 11-d010nr Battery Replacement, Lift the keyboard out: шаг 6, изображение 1 из 1
    • Gently lift the keyboard out of the laptop to fully detach it from the device.
    • While handling, avoid damaging any remaining components.
    Спросите у FixBot
  7. HP Stream 11-d010nr Battery Replacement, Battery: шаг 7, изображение 1 из 1
    • Remove any tape holding the battery connector in place.
    • Using your fingers, carefully unplug the battery.
    Спросите у FixBot
  8. HP Stream 11-d010nr Battery Replacement: шаг 8, изображение 1 из 2 HP Stream 11-d010nr Battery Replacement: шаг 8, изображение 2 из 2
    • Remove the four 3mm #000 Phillips screws holding the battery in place.
    • Carefully lift the battery out of the laptop.
    Спросите у FixBot
Заключение
4 человек успешно провели ремонт по этому руководству.
Zachary Heisler
Участник с: 01/24/19
382 Репутация
Автор 3 руководств
Команда
Cal Poly, Team S1-G3, White Winter 2019 Участник Cal Poly, Team S1-G3, White Winter 2019
CPSU-WHITE-W19S1G3
4 членов
Автор 11 руководств
3 Комментарии к руководству
HP lists the screws on the back cover as size pm1.9x5.6. What is wrong with HP that they would use such an odd size? I tried 2x6mm and they seem to work fine.
Greg Worrel - Ответить Поделиться
Me podrias ayudar con el numero de serie del boton de encendido
sam Carrizales - Ответить Поделиться
O donde lo puedo conseguir
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 12
За последние 30 дней: 61
За всё время: 3,567
