Введение
An HP Stream 11-d010nr can develop a faulty clickpad through mechanical or electrical malfunctions. This replacement is fairly straightforward and should only take 5-10 minutes. Unplug and power off your device before you attempt to open the device.
Выберете то, что вам нужно
Using a spudger, gently pry off the two elliptical rubber inserts located in the top corners.
Carefully remove the two circular rubber inserts positioned beneath the removed elliptical inserts.
Using a Phillips #1 screwdriver, remove the eleven 5.6 mm screws securing the back cover.
Using an iFixit opening tool, carefully pry open the case to separate the keyboard from the main body. Work slowly to avoid damaging the edges.
Carefully lift the keyboard and identify the three ribbon cables connecting the main body of the laptop to the keyboard.
Using a spudger, gently lift the flaps on the ZIF connectors to release the three ribbon cables securely attached to them.
Carefully disconnect the three ribbon cables.
Gently lift the keyboard out of the laptop to fully detach it from the device.
