HP Stream 11-d010nr Webcam Replacement
Выберете то, что вам нужно
  1. HP Stream 11-d010nr Webcam Replacement, Pry out the inserts: шаг 1, изображение 1 из 2 HP Stream 11-d010nr Webcam Replacement, Pry out the inserts: шаг 1, изображение 2 из 2
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Using a spudger, gently pry off the two elliptical rubber inserts located in the top corners.
    • Carefully remove the two circular rubber inserts positioned beneath the removed elliptical inserts.
    Спросите у FixBot
    Добавить комментарий
  2. HP Stream 11-d010nr Webcam Replacement, Unscrew the back cover: шаг 2, изображение 1 из 1
    • Using a Phillips #1 screwdriver, remove the eleven 5.6 mm screws securing the back cover.
    • Keep the screws in a safe place for reassembly.
    Спросите у FixBot
  3. HP Stream 11-d010nr Webcam Replacement, Pry the keyboard casing up: шаг 3, изображение 1 из 2 HP Stream 11-d010nr Webcam Replacement, Pry the keyboard casing up: шаг 3, изображение 2 из 2
    • Using an iFixit opening tool, carefully pry open the case to separate the keyboard from the main body. Work slowly to avoid damaging the edges.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
    Спросите у FixBot
  4. HP Stream 11-d010nr Webcam Replacement, Identify the connectors: шаг 4, изображение 1 из 1
    • Carefully lift the keyboard and identify the three ribbon cables connecting the main body of the laptop to the keyboard.
    • Lift the keyboard with extreme care to avoid damaging the delicate ribbon cables. Applying excessive force can easily tear or break them easily.
    Спросите у FixBot
  5. HP Stream 11-d010nr Webcam Replacement, Disconnect the cables: шаг 5, изображение 1 из 3 HP Stream 11-d010nr Webcam Replacement, Disconnect the cables: шаг 5, изображение 2 из 3 HP Stream 11-d010nr Webcam Replacement, Disconnect the cables: шаг 5, изображение 3 из 3
    • Using a spudger, gently lift the flaps on the ZIF connectors to release the three ribbon cables securely attached to them.
    • Carefully disconnect the three ribbon cables.
    Спросите у FixBot
  6. HP Stream 11-d010nr Webcam Replacement, Lift the keyboard out: шаг 6, изображение 1 из 1
    • Gently lift the keyboard out of the laptop to fully detach it from the device.
    • While handling, avoid damaging any remaining components.
    Спросите у FixBot
  7. HP Stream 11-d010nr Webcam Replacement, Battery: шаг 7, изображение 1 из 1
    • Remove any tape holding the battery connector in place.
    • Using your fingers, carefully unplug the battery.
    Спросите у FixBot
  8. HP Stream 11-d010nr Webcam Replacement: шаг 8, изображение 1 из 2 HP Stream 11-d010nr Webcam Replacement: шаг 8, изображение 2 из 2
    • Remove the four 3mm #000 Phillips screws holding the battery in place.
    • Carefully lift the battery out of the laptop.
    Спросите у FixBot
  9. HP Stream 11-d010nr Webcam Replacement, Wifi Chip: шаг 9, изображение 1 из 2 HP Stream 11-d010nr Webcam Replacement, Wifi Chip: шаг 9, изображение 2 из 2
    • Unplug the black wire attached to the wireless chip.
    Спросите у FixBot
  10. HP Stream 11-d010nr Webcam Replacement: шаг 10, изображение 1 из 2 HP Stream 11-d010nr Webcam Replacement: шаг 10, изображение 2 из 2
    • Remove the one 3mm Phillips #000 screw holding the wireless chip in place.
    • Lift the wireless chip up and out.
    Спросите у FixBot
  11. HP Stream 11-d010nr Webcam Replacement, Webcam: шаг 11, изображение 1 из 3 HP Stream 11-d010nr Webcam Replacement, Webcam: шаг 11, изображение 2 из 3 HP Stream 11-d010nr Webcam Replacement, Webcam: шаг 11, изображение 3 из 3
    • Flip up the flap and unplug the display cord from the motherboard.
    Спросите у FixBot
  12. HP Stream 11-d010nr Webcam Replacement: шаг 12, изображение 1 из 2 HP Stream 11-d010nr Webcam Replacement: шаг 12, изображение 2 из 2
    • Using a JIS #1 screwdriver, remove the four 2.2 mm screws holding monitor to body.
    Спросите у FixBot
  13. HP Stream 11-d010nr Webcam Replacement: шаг 13, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Use tweezers to remove the screw covers from the lid.
    • Unscrew the two 2.2 mm #000 Phillips screws.
    Спросите у FixBot
  14. HP Stream 11-d010nr Webcam Replacement: шаг 14, изображение 1 из 1
    • Open the upper lid with the iFixit opening tool.
    Спросите у FixBot
  15. HP Stream 11-d010nr Webcam Replacement: шаг 15, изображение 1 из 2 HP Stream 11-d010nr Webcam Replacement: шаг 15, изображение 2 из 2
    • Disconnect the webcam cord using tweezers.
    • Remove the webcam using tweezers.
    Спросите у FixBot
Заключение
Zachary Heisler
Участник с: 01/24/19
382 Репутация
Автор 3 руководств
Команда
Cal Poly, Team S1-G3, White Winter 2019 Участник Cal Poly, Team S1-G3, White Winter 2019
CPSU-WHITE-W19S1G3
4 членов
Автор 11 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 6
За последние 30 дней: 37
За всё время: 707
