HP Stream 7 Motherboard Replacement
Выберете то, что вам нужно
    1. HP Stream 7  Motherboard Replacement, Battery: шаг 1, изображение 1 из 2 HP Stream 7  Motherboard Replacement, Battery: шаг 1, изображение 2 из 2
      • Make sure the tablet is powered off before beginning.
      • Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
      Спросите у FixBot
      Добавить комментарий
    2. HP Stream 7  Motherboard Replacement: шаг 2, изображение 1 из 2 HP Stream 7  Motherboard Replacement: шаг 2, изображение 2 из 2
      • Remove the eight 5 mm Phillips 000 screws.
      • Gently run the plastic opening tool around the seam to pry the mid back cover from the tablet.
      Спросите у FixBot
    3. HP Stream 7  Motherboard Replacement: шаг 3, изображение 1 из 2 HP Stream 7  Motherboard Replacement: шаг 3, изображение 2 из 2
      Инструмент, используемый на этом этапе:
      • Using tweezers, gently pull the battery connector towards the battery to remove it from the System Board.
      • Pull the blue tabs (Not Shown) out from the tablet at an angle to remove the tape underneath the Battery.
      • If you broke both tabs, scrape the tape and Battery off.
      • Scraping off the Battery will damage it. If you are replacing another part, leave the Battery on the display panel.
      Спросите у FixBot
    1. HP Stream 7  Motherboard Replacement, Motherboard Replacement: шаг 4, изображение 1 из 1
      • Disconnect the battery from the motherboard, but leave the battery on the display panel (unless you have already taken it off).
      • Disconnect the motherboard from the rear-facing camera, the front-facing camera, the antenna, the power button board, the screen, and the display panel using your spudger.
      • The cable connected to the display is adhered to the panel, so be careful when removing the cable (like most things here).
      • If you are inexperienced with disconnecting everything, "Recognizing and Disconnecting Cable Connectors" is a helpful ifixit guide.
      Спросите у FixBot
    2. HP Stream 7  Motherboard Replacement: шаг 5, изображение 1 из 2 HP Stream 7  Motherboard Replacement: шаг 5, изображение 2 из 2
      • Remove the two 2 mm Phillips 000 screws from the motherboard.
      Спросите у FixBot
    3. HP Stream 7  Motherboard Replacement: шаг 6, изображение 1 из 2 HP Stream 7  Motherboard Replacement: шаг 6, изображение 2 из 2
      • Once unscrewed, the motherboard separates from the rest of the device.
      • The speaker is soldered to the motherboard, but it comes off easily.
      • Forced separation may result in a damaged motherboard and/or personal injury.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Justin Schnorf
Участник с: 10/03/16
252 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 18-5, Forte Fall 2016 Участник Cal Poly, Team 18-5, Forte Fall 2016
CPSU-FORTE-F16S18G5
4 членов
Автор 6 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 12
За последние 30 дней: 47
За всё время: 2,103
