HP Stream 7 Screen Replacement
Выберете то, что вам нужно
    1. HP Stream 7  Screen Replacement, Battery: шаг 1, изображение 1 из 2 HP Stream 7  Screen Replacement, Battery: шаг 1, изображение 2 из 2
      • Make sure the tablet is powered off before beginning.
      • Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
      Спросите у FixBot
      Добавить комментарий
    2. HP Stream 7  Screen Replacement: шаг 2, изображение 1 из 2 HP Stream 7  Screen Replacement: шаг 2, изображение 2 из 2
      • Remove the eight 5 mm Phillips 000 screws.
      • Gently run the plastic opening tool around the seam to pry the mid back cover from the tablet.
      Спросите у FixBot
    3. HP Stream 7  Screen Replacement: шаг 3, изображение 1 из 2 HP Stream 7  Screen Replacement: шаг 3, изображение 2 из 2
      Инструмент, используемый на этом этапе:
      • Using tweezers, gently pull the battery connector towards the battery to remove it from the System Board.
      • Pull the blue tabs (Not Shown) out from the tablet at an angle to remove the tape underneath the Battery.
      • If you broke both tabs, scrape the tape and Battery off.
      • Scraping off the Battery will damage it. If you are replacing another part, leave the Battery on the display panel.
      Спросите у FixBot
    1. HP Stream 7  Screen Replacement, Motherboard Replacement: шаг 4, изображение 1 из 1
      • Disconnect the battery from the motherboard, but leave the battery on the display panel (unless you have already taken it off).
      • Disconnect the motherboard from the rear-facing camera, the front-facing camera, the antenna, the power button board, the screen, and the display panel using your spudger.
      • The cable connected to the display is adhered to the panel, so be careful when removing the cable (like most things here).
      • If you are inexperienced with disconnecting everything, "Recognizing and Disconnecting Cable Connectors" is a helpful ifixit guide.
      Спросите у FixBot
    2. HP Stream 7  Screen Replacement: шаг 5, изображение 1 из 2 HP Stream 7  Screen Replacement: шаг 5, изображение 2 из 2
      • Remove the two 2 mm Phillips 000 screws from the motherboard.
      Спросите у FixBot
    3. HP Stream 7  Screen Replacement: шаг 6, изображение 1 из 2 HP Stream 7  Screen Replacement: шаг 6, изображение 2 из 2
      • Once unscrewed, the motherboard separates from the rest of the device.
      • The speaker is soldered to the motherboard, but it comes off easily.
      • Forced separation may result in a damaged motherboard and/or personal injury.
      Спросите у FixBot
    1. HP Stream 7  Screen Replacement, Screen Replacement: шаг 7, изображение 1 из 1
      • After removing the motherboard, unscrew the four 2.5 mm Phillips 000 screws from the display panel.
      Спросите у FixBot
    2. HP Stream 7  Screen Replacement: шаг 8, изображение 1 из 1
      • Using your spudger, pry the display panel off the front.
      Спросите у FixBot
    3. HP Stream 7  Screen Replacement: шаг 9, изображение 1 из 1
      • The screen should now just come right off. Be sure to catch any broken bits if the screen is damaged.
      Спросите у FixBot
Заключение
6 человек успешно провели ремонт по этому руководству.
Justin Schnorf
Участник с: 10/03/16
252 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 18-5, Forte Fall 2016 Участник Cal Poly, Team 18-5, Forte Fall 2016
CPSU-FORTE-F16S18G5
4 членов
Автор 6 руководств
6 Комментарии к руководству
where can i buy new screen????
eibrims - Ответить Поделиться
Yeah, I want to know where I can buy a screen for my hp stream 7.
Rider Sd - Ответить Поделиться
Where can i buy a new screen for the stream 7 please??
migueajr - Ответить Поделиться
Same question but no answer !
Where can anyone find replacement screen online ??
Ahmed Saleh - Ответить Поделиться
We're I can buy the replacement screen?
Raymond Borrero - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 13
За последние 30 дней: 34
За всё время: 4,742
