HP ZBook 15 Keyboard Replacement
Выберете то, что вам нужно
    1. HP ZBook 15 Keyboard Replacement, Battery: шаг 1, изображение 1 из 2 HP ZBook 15 Keyboard Replacement, Battery: шаг 1, изображение 2 из 2
      • Flip the laptop over.
      • Slide the lever with the battery symbol beside it firmly until the battery pops out.
      • Remove the battery from the laptop.
      Спросите у FixBot
      Добавить комментарий
    1. HP ZBook 15 Keyboard Replacement, Back Cover: шаг 2, изображение 1 из 1
      • Slide the right lever firmly to the right.
      • Slide the cover towards yourself to remove it.
      Спросите у FixBot
    1. HP ZBook 15 Keyboard Replacement, Keyboard: шаг 3, изображение 1 из 1
      • Remove the two 16mm screws with a Phillips #0 screwdriver.
      • There are two sets of threads to get past. Once unscrewed from the first thread, lift the screw up until it hits the next set and begin unscrewing again.
      Спросите у FixBot
    2. HP ZBook 15 Keyboard Replacement: шаг 4, изображение 1 из 3 HP ZBook 15 Keyboard Replacement: шаг 4, изображение 2 из 3 HP ZBook 15 Keyboard Replacement: шаг 4, изображение 3 из 3
      • Do not try to pry the keyboard from the bottom. The keyboard is attached by clips on the left, top, and right side. Metal inserts on the bottom side lock the keyboard in place until they are slid up and out.
      • Be careful not to scratch or chip the computer when prying. If you have a plastic tool that is long enough to gain leverage, use that instead of a metal tool.
      • There are ribbons secured underneath so be careful not to pull the keyboard out too hard, breaking the connections to the ribbons.
      • Flip the laptop over so the keyboard is visible.
      • Insert the spudger under the left side of the keyboard.
      • Carefully raise the side of the keyboard and firmly pull the left corner of the keyboard until it pops up.
      • Run your fingers under the edges of the keyboard along the top edge of the keyboard, from the top left to the top right, to separate it from the remaining clips.
      • Carefully slide the keyboard up toward the screen and out of the case.
      Спросите у FixBot
    3. HP ZBook 15 Keyboard Replacement: шаг 5, изображение 1 из 3 HP ZBook 15 Keyboard Replacement: шаг 5, изображение 2 из 3 HP ZBook 15 Keyboard Replacement: шаг 5, изображение 3 из 3
      • Gently lift the two tabs on either side of the black ribbon with a spudger until the ribbon comes loose.
      • Disconnect the black ribbon by pulling the blue tab hanging off of it.
      • Repeat with the white ribbon.
      Спросите у FixBot
Заключение
34 человек успешно провели ремонт по этому руководству.
Grant Terris
Участник с: 01/30/15
2 888 Репутация
Автор 12 руководств
Команда
Cal Poly, Team 8-43, Amido Winter 2015 Участник Cal Poly, Team 8-43, Amido Winter 2015
CPSU-AMIDO-W15S8G43
4 членов
Автор 107 руководств
13 Комментарии к руководству
I found that if you remove the optical drive, you have access to push the keyboard form the back to disengage the side with the number pad.
bryanholder81 - Ответить Поделиться
I agree with Bryan...much easier to start that way. Pushing from the back will disengage the top right corner (seen from the user position)
advrider - Ответить Поделиться
In addition to the comments about pushing the keyboard out after removing the optical drive (which is actually the documented way of removing the keyboard) I'd add that the bit about "There are two sets of threads to get past. Once unscrewed from the first thread, lift the screw up until it hits the next set and begin unscrewing again." is incorrect. The screws are deliberately designed to be self retaining. You only need to unscrew it until the screw turns freely (i.e. not fully).
Dominic Cioccarelli - Ответить Поделиться
please, will they have the part number of this keyboard ?, it hurt me and I saw the steps that are followed to extract it, and replace it, but I can not find the part number of the keyboard replacement, if someone could have it tell me which is please?
cesar rios - Ответить Поделиться
Go to partsurfer.hp.com with the p/n of the machine and you'll get the exact part number of the keyboard you need
Johan Rios - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 28
За последние 30 дней: 142
За всё время: 70,680
