HTC Incredible 2 Volume Button Replacement
Выберете то, что вам нужно
  1. HTC Incredible 2 Volume Button Replacement, Disassembling HTC Incredible 2 Back Panel: шаг 1, изображение 1 из 2 HTC Incredible 2 Volume Button Replacement, Disassembling HTC Incredible 2 Back Panel: шаг 1, изображение 2 из 2
    • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
    • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
    Спросите у FixBot
    Добавить комментарий
  2. HTC Incredible 2 Volume Button Replacement: шаг 2, изображение 1 из 1
    • Remove the rear panel from the phone.
    Спросите у FixBot
  3. HTC Incredible 2 Volume Button Replacement, Battery: шаг 3, изображение 1 из 1
    • Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
    • Use a penny or dime if you can't use your fingernail.
    Спросите у FixBot
  4. HTC Incredible 2 Volume Button Replacement: шаг 4, изображение 1 из 2 HTC Incredible 2 Volume Button Replacement: шаг 4, изображение 2 из 2
    • Gently lever the battery up and away from the lights.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
    Спросите у FixBot
  5. HTC Incredible 2 Volume Button Replacement, Mid Panel: шаг 5, изображение 1 из 1
    • Remove the seven 1.42 mm Torx T5 screws
    Спросите у FixBot
  6. HTC Incredible 2 Volume Button Replacement: шаг 6, изображение 1 из 2 HTC Incredible 2 Volume Button Replacement: шаг 6, изображение 2 из 2
    • Use a plastic opening tool to run along the phone's side and lever mid panel upward.
    • Apply minimal pressure as the mid panel is very delicate.
    Спросите у FixBot
  7. HTC Incredible 2 Volume Button Replacement: шаг 7, изображение 1 из 1
    • Gently grasp and carefully lift mid panel up and away from the device with your fingers.
    Спросите у FixBot
  8. HTC Incredible 2 Volume Button Replacement, Volume Button: шаг 8, изображение 1 из 3 HTC Incredible 2 Volume Button Replacement, Volume Button: шаг 8, изображение 2 из 3 HTC Incredible 2 Volume Button Replacement, Volume Button: шаг 8, изображение 3 из 3
    • Firmly grasp the volume button from the mid panel on the clip side
    • Gently lift the button upwards and remove it
    Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Robert Trujillo
Участник с: 04/25/14
246 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 11-53, Amido Spring 2014 Участник Cal Poly, Team 11-53, Amido Spring 2014
CPSU-AMIDO-S14S11G53
5 членов
Автор 21 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 1
За последние 30 дней: 20
За всё время: 572
