HTC One Mini Screen Replacement
Выберете то, что вам нужно
    1. HTC One Mini Screen Replacement, Screen: шаг 1, изображение 1 из 1
      • Use a plastic opening tool to remove the bottom speaker cover
      Спросите у FixBot
      Добавить комментарий
    2. HTC One Mini Screen Replacement: шаг 2, изображение 1 из 1
      • Use your T6 Torx screwdriver to remove the single screw that holds the body to the aluminium back
      Спросите у FixBot
    3. HTC One Mini Screen Replacement, This step requires a little patience: шаг 3, изображение 1 из 2 HTC One Mini Screen Replacement, This step requires a little patience: шаг 3, изображение 2 из 2
      • Use only plastic opening tools, metal ones will cause damage to the assembly
      • Use a plastic opening tool next to the usb port to gently lift the bottom away from the backing.
      • Use a second tool to work your way around the phone undoing the clips while the first tool lifts the undone areas
      Спросите у FixBot
    4. HTC One Mini Screen Replacement: шаг 4, изображение 1 из 1
      • Use your heat gun and infra-red thermometer to heat the screen assembly to 130 degrees C (265 F) to soften the adhesive
      • Use opening tool to gently lift the edges of the screen away from the body working from the top down.
      • Don't try to remove the bottom of the screen as your flex cables are there and still attached to the logic board
      Спросите у FixBot
    5. HTC One Mini Screen Replacement: шаг 5, изображение 1 из 1
      • Undo the 2 Phillips screws circled in red and detach the battery connector (so we don't short anything out)
      • Undo the 3 screws holding down the bottom of the logic board and charger port circled in green
      • Undo the flex cables and speaker power cable circled in blue and lift the charger port out
      • The flex cable for this board and the one next to it for the screen their locking tabs open from the back
      • Gently using a plastic opening tool lift out the bottom speaker
      • Also the rubber spacer circled in blue
      • Undo the flex cables circled in orange and slowly start pulling the old screen out
      Спросите у FixBot
    6. HTC One Mini Screen Replacement: шаг 6, изображение 1 из 1
      • Remove any old adhesive and broken glass from the frame
      • Gently feed through the flex cables taking great care not to break them
      • Don't remove any of this sheilding tape, I have only removed it to show you that there is nothing under there and I have replaced it during reassembly
      Спросите у FixBot
    7. HTC One Mini Screen Replacement: шаг 7, изображение 1 из 1
      • Fold the screen away from the body keeping in mind not to damage the flex cables.
      • Add your strips of adhesive tape to the frame and put put the screen onto the body (I have highlighted the placement areas in blue)
      • You will have to cut the tape in half for the sides of the screen. Using a razor blade and a metal ruler will give best results.
      • Follow the steps in reverse for reassembly and use a couple of drops of super glue to put the front speaker cover back on
      Спросите у FixBot
Заключение
10 человек успешно провели ремонт по этому руководству.
Robbie
Участник с: 07/11/14
655 Репутация
1 руководство автора
2 Комментарии к руководству
I just need to change the touch digitizer, how do I detach it from the LCD?
hudeor - Ответить Поделиться
Where can i find a replacement screen
pietro.faraggiana - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 40
За всё время: 37,519
