HVAC Filter Replacement
Выберете то, что вам нужно
    1. HVAC Filter Replacement, Filter: шаг 1, изображение 1 из 1
      • Observe your air conditioning vent. If the filter appears to be dirty or damaged, then it is time to change it.
      Спросите у FixBot
      Добавить комментарий
    2. HVAC Filter Replacement: шаг 2, изображение 1 из 1
      • Remove the screws on the vent cover. There should be a minimum of 4 screws in each corner of the vent.
      • The screws in this vent are phillips hex head screws that are 1 3/4 in. long.
      Спросите у FixBot
    3. HVAC Filter Replacement: шаг 3, изображение 1 из 1
      • Grab a screwdriver with a hex head attachment to remove the screws. Grab the screwdriver and place it on the head of the screw. Twist in a counterclockwise motion until the screw is removed. Repeat for every screw.
      Спросите у FixBot
    4. HVAC Filter Replacement: шаг 4, изображение 1 из 1
      • Remove the vent cover to access the ventilation filter.
      Спросите у FixBot
    5. HVAC Filter Replacement: шаг 5, изображение 1 из 1
      • Optional: Put on a latex glove on the hand that you will use to remove the filter.
      Спросите у FixBot
    6. HVAC Filter Replacement: шаг 6, изображение 1 из 1
      • Remove the filter carefully.
      • Make sure to remove it slowly so that the dust does not come of it.
      Спросите у FixBot
    7. HVAC Filter Replacement: шаг 7, изображение 1 из 1
      • Dispose of the old filter in a waste bin.
      Спросите у FixBot
    8. HVAC Filter Replacement: шаг 8, изображение 1 из 1
      • Buy a Honeywell Air Filter from Home Depot and make sure to buy the filter with the correct dimensions.
      • The dimensions for filters will vary depending on the dimensions of the vent.
      • In this case, my vent was 14x25x1 and thus needed a filter with the same dimensions.
      Спросите у FixBot
    9. HVAC Filter Replacement: шаг 9, изображение 1 из 1
      • Place the new filter into the vent opening. Make sure that it is facing the right direction.
      • There will be an arrow on the side of the filter showing which way to place it.
      Спросите у FixBot
    10. HVAC Filter Replacement: шаг 10, изображение 1 из 1
      • Place vent cover.
      Спросите у FixBot
    11. HVAC Filter Replacement: шаг 11, изображение 1 из 1
      • Grab the same screws that were taken out at Step 3 and use them to secure the vent cover.
      • Place the screwdriver on the head of the screw and twist in a clockwise motion until screw is secure.
      • Repeat for every screw.
      Спросите у FixBot
    12. HVAC Filter Replacement: шаг 12, изображение 1 из 1
      • Turn on your air conditioner to make sure the filter does not move.
      • If the filter does not move, then you have successfully replaced the filter of your air conditioner.
      Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Anthony Estevez
Участник с: 10/20/23
67 Репутация
1 руководство автора
Команда
CSU Los Angeles, Team 2-1, Briggs Fall 2023 Участник CSU Los Angeles, Team 2-1, Briggs Fall 2023
CSULA-BRIGGS-F23S2G1
5 членов
Автор 60 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 19
За последние 30 дней: 69
За всё время: 1,035
