Hair Dryer Button Switchboard Replacement
Выберете то, что вам нужно
    1. Hair Dryer Button Switchboard Replacement, Nozzle: шаг 1, изображение 1 из 2 Hair Dryer Button Switchboard Replacement, Nozzle: шаг 1, изображение 2 из 2
      • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
      • If nozzle is not attached, skip to next step.
      Спросите у FixBot
      Добавить комментарий
    1. Hair Dryer Button Switchboard Replacement, Grating: шаг 2, изображение 1 из 1
      • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
      • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
      Спросите у FixBot
    2. Hair Dryer Button Switchboard Replacement: шаг 3, изображение 1 из 1
      • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
      Спросите у FixBot
    3. Hair Dryer Button Switchboard Replacement: шаг 4, изображение 1 из 1
      • Separate the hair dryer grating into the three pieces seen in the image.
      Спросите у FixBot
    1. Hair Dryer Button Switchboard Replacement, Button Switchboard: шаг 5, изображение 1 из 1
      • Using a Phillips #1 Screwdriver, remove the screws located on the hair dryer handle.
      Спросите у FixBot
    2. Hair Dryer Button Switchboard Replacement: шаг 6, изображение 1 из 1
      Спросите у FixBot
    3. Hair Dryer Button Switchboard Replacement: шаг 7, изображение 1 из 1
      • The hairdryer is now disassembled. The fan, motor, heating element cover, and internal wiring are exposed.
      • Please be careful around these parts of the hairdryer. Even if the device is off, they may be warm to the touch.
      • This is the TURBO button.
      • This is the SWITCHBOARD button.
      Спросите у FixBot
    4. Hair Dryer Button Switchboard Replacement: шаг 8, изображение 1 из 1
      • Gently pull the turbo button away from the hair dryer body.
      • If the turbo setting is still not working after you replace the switchboard, consider using soldering techniques to replace the turbo button. It may be why the hairdryer is not working properly, too.
      Спросите у FixBot
    5. Hair Dryer Button Switchboard Replacement: шаг 9, изображение 1 из 1
      • Gently pull the button switchboard away from the hair dryer body.
      • Using a desoldering wick and a soldering iron, desolder the wires. This will help with the electrical connection issues that may be occurring.
      • Refer to the following page for desoldering instructions: Soldering Skills
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Mitch
Участник с: 10/04/12
37 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 24-29, Regan Fall 2012 Участник Cal Poly, Team 24-29, Regan Fall 2012
CPSU-REGAN-F12S24G29
5 членов
Автор 11 руководств
1 Комментарий к руководству
I have a hairdryer with loose wire. Can you help me to find where the wire should be welded?
ziad musa - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 21
За последние 30 дней: 88
За всё время: 10,294
