Введение
This guide will walk you through the easy process of repairing or replacing the heater control buttons.
Выберете то, что вам нужно
Turn heater over so the controls are facing up.
Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
Remove four 12mm Phillips #2 screws from the circuit board.
Remove the two Phillips #2 12mm screws from the button retainer.
Lift the button retainer off.
Remove the interconnected buttons.
If the buttons are broken, replace them.
If the buttons are sticking, clean them in warm soapy water and allow to dry.
Using light finger pressure, carefully push the black plastic tabs off the white plastic hooks.
Remove the black plastic bracket out through the front of the heater housing.
Remove the two Phillips #2 12mm screws and remove the clear window from the black plastic bracket.
If the buttons were sticking, clean the black plastic bracket in warm soapy water and allow to dry.
If the clear window was dirty, clean it in warm soapy water and allow to dry.
Еще один человек закончил это руководство.
