Введение
The first step to replacing any internal component in the hoverboard is to remove the external plastic covers. You will need a Phillips #2 screwdriver with a long shaft for this guide.
Выберете то, что вам нужно
Flip the hoverboard over so the labels are facing upwards.
Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
Remove one connector from the non-battery side circuit board.
Remove the next connector from the non-battery side circuit board.
3 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
I'm gettin nothin at all.. Charger is green.. But absolutely nothing when press the on button.. All the cables are connected.. No lights or anythin.. Can anyone help.
I am getting the 5 red lights. I have followed all the instructions. Is there a site to buy the motherboards that are burned out? Is it financially worth buy both boards and replacing them?
-Christopher Fields, Network Engineer, PC Repair, Grantsville, UT
