Введение
If your Nomad does not power on, the power button may be damaged. Follow this guide to replace the power button in the Hover-1 Nomad.
Выберете то, что вам нужно
Break the two warranty stickers by poking a screwdriver through them or peeling them off.
Remove the following twenty screws by rotating the screwdriver counterclockwise:
Eight 16.2mm Phillips #2 screws
Eight 15mm Phillips #2 screws
Four 19.1mm Phillips #2 screws
Use a nylon spudger to pry the metal handle away from the outer shell.
Rotate the metal handle toward the center of the hoverboard to unlock the plate from the retaining clips.
Lift the hoverboard off the metal handle.
Repeat for the handle on the other side of the hoverboard.
Disconnect the following wires by pinching the connector tabs and pulling the plugs out of the connectors:
Charging port wires
Speaker assembly wires
Power button wires
Headlight wires
Peel off the glue around the power button.
Unscrew the hexagonal nut around the power button by rotating the nut counterclockwise with a pair of pliers.
Feed the wire and connector through the removed nut and pull the power button out through the hole in the outer casing.
Еще один человек закончил это руководство.
