How To Restring a Yo-Yo
Выберете то, что вам нужно
  1. How To Restring a Yo-Yo, String: шаг 1, изображение 1 из 1
    • Unscrew one half of the Yo-Yo from the other by twisting them in opposing directions.
    Спросите у FixBot
    Добавить комментарий
  2. How To Restring a Yo-Yo: шаг 2, изображение 1 из 1
    • Analyze the current state of the string.
    • If the string is worn out, you must determine whether or not you want to put it back in place and keep using the Yo-Yo till the string fully breaks or replace the string right away.
    • If the string is damaged beyond repair, then get your new string ready.
    Спросите у FixBot
  3. How To Restring a Yo-Yo: шаг 3, изображение 1 из 1
    • Find the end of the string that does not have a knot tied around it. This end of the string is the finger hole.
    • We are not interested in this end. You will know you have the right end if you can smoothly run a finger along the string.
    Спросите у FixBot
  4. How To Restring a Yo-Yo: шаг 4, изображение 1 из 1
    • Pull at the threading, making a hole that is just big enough to fit onto the ball bearing.
    • Avoid creating a hole that is bigger than necessary, it’s good practice to do so.
    Спросите у FixBot
  5. How To Restring a Yo-Yo: шаг 5, изображение 1 из 1
    • Place the hole over the bearing, allowing the string to rest on the half of the Yo-Yo with the ball bearing.
    Спросите у FixBot
  6. How To Restring a Yo-Yo: шаг 6, изображение 1 из 1
    • Hold the half with the ball bearing with one hand and gently tug on the string with your other hand.
    • This will ensure that the placement of the string is secure.
    Спросите у FixBot
  7. How To Restring a Yo-Yo: шаг 7, изображение 1 из 1
    • Screw the halves back together firmly, making sure that they are aligned correctly.
    • You shouldn't make the halves tighter than 'hand-tight'. This is good for you and the Yo-Yo so you won't have much trouble trying to open it up.
    Спросите у FixBot
  8. How To Restring a Yo-Yo: шаг 8, изображение 1 из 1
    • Wind up your Yo-Yo and try do a trick to ensure that you’ve done a good job in restringing your Yo-Yo. Now you can enjoy your ‘Yo-Yoing’!
    Спросите у FixBot
Заключение
After following these steps, you will have successfully restrung your Yo-Yo.
3 человек успешно провели ремонт по этому руководству.
Mark Amirthanathan
Участник с: 01/19/21
205 Репутация
1 руководство автора
Команда
York University, Team S1-G1, Melo-Thaiss Winter 2021 Участник York University, Team S1-G1, Melo-Thaiss Winter 2021
YORK-MELO-THAISS-W21S1G1
1 член
Автор 2 руководств
1 Комментарий к руководству
nice tutorial
sdsdsds - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 25
За последние 30 дней: 97
За всё время: 6,197
