How to Fix a Mirror Frame
Выберете то, что вам нужно
    1. How to Fix a Mirror Frame, How to Fix a Mirror Frame: шаг 1, изображение 1 из 1
      • Gather all your broken frame pieces and gently clean off any dust or debris. Once the pieces are clean, arrange them to determine how they fit back into the damaged section. This will help you understand the order in which they need to be glued.
      Спросите у FixBot
      Добавить комментарий
    2. How to Fix a Mirror Frame: шаг 2, изображение 1 из 1
      • Once the pieces are arranged, apply a small amount of Gorilla Glue to the edges that need to be reattached. Press each piece firmly into place. Work slowly to make sure each section aligns with the original shape of the frame.
      • Caution: Gorilla Glue expands as it dries. Use sparingly to prevent overflow onto the visible surface.
      Спросите у FixBot
    3. How to Fix a Mirror Frame: шаг 3, изображение 1 из 1
      • Use tension bands (rubber bands or elastic straps) to hold the pieces tightly together while the glue cures. Place the bands so that they apply gentle, even pressure across the repaired area without pressing against the mirror glass. Let the glue dry according to the instructions on the adhesive bottle.
      Спросите у FixBot
    4. How to Fix a Mirror Frame: шаг 4, изображение 1 из 2 How to Fix a Mirror Frame: шаг 4, изображение 2 из 2
      • Once the glue is fully dry, check for any gaps or visible seams between the pieces. Use clay or wood filler to fill in the gaps to create a smooth, continuous surface. Shape the filler to match the pattern and curves of the existing frame. Allow the filler to dry completely before moving on.
      Спросите у FixBot
    5. How to Fix a Mirror Frame: шаг 5, изображение 1 из 2 How to Fix a Mirror Frame: шаг 5, изображение 2 из 2
      • After the filler has dried, mix your paint to match the color and finish of the frame. Use a small brush or sponge to apply the paint to the repaired areas. Blend it carefully so it matches the rest of the frame. Allow the paint to dry fully before handling.
      Спросите у FixBot
    6. How to Fix a Mirror Frame: шаг 6, изображение 1 из 1
      • Let the repaired mirror frame dry for 24 hours. Once everything is set, your mirror should be fully restored and ready to use again.
      Спросите у FixBot
Финишная прямая
Regina Bolanos
Участник с: 06/11/25
133 Репутация
1 руководство автора
Команду
University of North Texas, Team 40-2, Kilpatrick Summer 2025 Участник University of North Texas, Team 40-2, Kilpatrick Summer 2025
UNT-KILPATRICK-SU25S40G2
1 член
Автор 12 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 56
За последние 30 дней: 182
За всё время: 1,175
