Введение
If you wanted to change out your license plate lights, installing new LED license plate lamps is actually quite a piece of cake. You will have a new look with minimal effort in no time. This installation will not take much time and is great for beginners.
Выберете то, что вам нужно
You can choose to raise your car with a car lift jack to get better access to the license plate area. This is not absolutely necessary, but will make installation easier.
Pull out the license plate lamp assembly and remove the stock license plate bulb.
Install back the new LED license plate bulb.
Test to make sure the LED bulb works.
Put the license plate assembly back and repeat on the other side.
See how easy installing these LED license plate lights are? It's almost unbelievable how a quick and simple installation could make such a difference.
6 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
Why do all your pics have such obnoxious watermarks? If the pics are specifically for iFixit.com I would remove the watermarks.
Good information!
