How to Install Ubuntu Linux
Выберете то, что вам нужно
  1. How to Install Ubuntu Linux, Download Ubuntu: шаг 1, изображение 1 из 1
    Спросите у FixBot
    Добавить комментарий
  2. How to Install Ubuntu Linux, Burn to Disk: шаг 2, изображение 1 из 2 How to Install Ubuntu Linux, Burn to Disk: шаг 2, изображение 2 из 2
    • Use disk burning software like ImgBurn to burn Ubuntu to a DVD, or you can use a USB flash drive instead. If you use a flash drive, download UNetbootin and create your installation media.
    • You do not need to burn Ubuntu to a disk if you are using a virtual machine.
    Спросите у FixBot
  3. How to Install Ubuntu Linux, Boot to installation media: шаг 3, изображение 1 из 1
    • I recommend trying Ubuntu in a virtual machine, which is what I did.
    • If you are using a real computer, you may need to configure the BIOS or press a key on system startup. If you need to change the BIOS settings, set any Optical Drives or USB CD-ROM drives as the first boot priority.
    • If you want to use a virtual machine, set CD/DVD as the first boot priority and mount the iso file to the machine. There is plenty of virtualization software out there, like VirtualBox.
    • If you have successfully booted into the installation media, you will see this picture.
    • Click on the big "Install Ubuntu" button.
    Спросите у FixBot
  4. How to Install Ubuntu Linux, Install Ubuntu: шаг 4, изображение 1 из 1
    • After a screen asking about additional software, you will asked what you would like to do with your hard disk.
    • If the installer refers to any sort of dual-booting, you must quit the installer and make unallocated space on your hard disk somehow. (See warning for info.)
    • If you are experienced with partitions, you may use this partition editor.
    • If you decide to use the partition editor, please be very careful. Partitions made with this partition editor can cause any other operating systems to become inaccessible.
    Спросите у FixBot
Заключение
That's it! Now you can try Ubuntu all you want.
7 человек успешно провели ремонт по этому руководству.
Thomas Sirack
Участник с: 07/25/15
561 Репутация
Автор 2 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 52
За всё время: 1,523
