Введение
This guide shows how to install and remove the Tiles on your Framework Desktop.
The Tiles are mainly for decoration; they aren't necessary for your desktop to function.
The Front Panel can support up to 21 tiles.
Выберете то, что вам нужно
Use your fingers to pull the Front Panel off the magnets securing it to the chassis.
Use your fingers to push the bottom of the Tile up and off the front panel and release its clips.
Remove the Tile.
Lay a Tile over an open slot on your Front Panel.
Use your fingers to press the tile into the slot and engage the clips.
Lay the bottom of the Front Panel on the small, protruding lip in the silver base to align its tabs.
Press the Front Panel flat to the chassis and let it align to the magnets.
If you need help, contact Framework support.
