How to JBL L40
Выберете то, что вам нужно
    1. How to JBL L40, How to JBL L40: шаг 1, изображение 1 из 1
      • To remove the speaker from the cabinet, unscrew the 4 screws being careful not to slip and pierce the paper cone.
      • Once the screws are removed gently pull the speaker out of the cabinet.
      • There will be 2 wires attached to the speaker, remove them making sure to mark the polarity of them if they are not marked already.
      Спросите у FixBot
      Добавить комментарий
    2. How to JBL L40: шаг 2, изображение 1 из 1
      • Here is the speaker removed from the cabinet, you can clearly see the degraded state of the foam surround. Luckily this makes it very easy to remove it.
      • These next steps require careful attention to detail. Work slowly and carefully. You do not want to puncture/tear/rip the paper cone or any other components.
      Спросите у FixBot
      • Remove the black foam ring.
      • Try to do as much of this by hand as you can. You do not want to damage the ring as you will need it for re assembly.
      • Carefully run your knife between the ring and the outer metal edge.
      • Now using your hands and knife when needed remove the black ring from the speaker frame. Prying slowly. Take care not to tear it.
      • Once the ring is removed rub all of the old foam surround off and set aside for reassembly
      Спросите у FixBot
      • Remove all of the old foam surround from the cone and speaker frame. It was so crumbly on mine that all it took was a bunch of rubbing with my fingers. If you are having trouble use your knife, but again be careful.
      Спросите у FixBot
    3. How to JBL L40: шаг 5, изображение 1 из 1
      • You can see some of the glue seeped out, it will dry clear so don't worry.
      Спросите у FixBot
    4. How to JBL L40: шаг 6, изображение 1 из 1
      • Spread glue on the ring you removed earlier
      • place over the foam ring and press on securly
      • allow everything over night to dry completely.
      Спросите у FixBot
    5. How to JBL L40: шаг 7, изображение 1 из 1
      • Connect the wires to the speaker being mindfull of the polarity.
      • Gently fit the speaker into the housing
      • Line up the screws and progressively tighten them until the speaker is secured
      Спросите у FixBot
Заключение
4 человек успешно провели ремонт по этому руководству.
David Salerno
Участник с: 09/14/11
823 Репутация
Автор 4 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 16
За последние 30 дней: 54
За всё время: 7,859
