Введение
GPS signal repair
Выберете то, что вам нужно
Видеоинструкции
Еще один человек закончил это руководство.
GPS signal repair
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 30
За всё время: 2,306
1 Комментарий к руководству
Hi sir, i have the exact same problem with GPS. At first i thought it’s a software problem so i tried every way i could find on the internet but none of them seem to work.
I read so many Zenfone user using your method solve the problem. I’d like to try it as well hoping my GPS will fixed.
My question is :
the GPS antenna separated in two parts which connected to two connectors. As i see the pics in your vid, do i have to connect only the upper part of antenna to the upper connector? and is it necessary to put the other end of cooper wire to the small hole below the sim card slot?
Any answer will be much appreciated.
Thank you from Bali
Vickkal Kristianes - Ответить Поделиться
