How to Run First Aid with Disk Utility
    1. How to Run First Aid with Disk Utility, How to Run First Aid with Disk Utility: шаг 1, изображение 1 из 2 How to Run First Aid with Disk Utility, How to Run First Aid with Disk Utility: шаг 1, изображение 2 из 2
      • Open Disk Utilities, which can be found in the Applications folder under Utilities
      • Pro Tip: Take the shortcut and use Spotlight. (This method is used in this guide)
      Спросите у FixBot
      Добавить комментарий
    2. How to Run First Aid with Disk Utility: шаг 2, изображение 1 из 2 How to Run First Aid with Disk Utility: шаг 2, изображение 2 из 2
      • Once the Disk Utility App opens, click the "View" menu.
      • Select "Show All Devices"
      • Older versions of macOS may not have this button. If so, skip to the next step.
      Спросите у FixBot
    3. How to Run First Aid with Disk Utility: шаг 3, изображение 1 из 1
      • In the Sidebar, click the last volume in the list.
      • By default it will likely be named "Macintosh HD - Data" or simply "Macintosh HD" on Macs running 10.14 Mojave or earlier.
      Спросите у FixBot
    4. How to Run First Aid with Disk Utility: шаг 4, изображение 1 из 3 How to Run First Aid with Disk Utility: шаг 4, изображение 2 из 3 How to Run First Aid with Disk Utility: шаг 4, изображение 3 из 3
      • Click on the First Aid button at the top of the window.
      • A dialogue box will appear asking if you would like to run First Aid.
      • Click "Run".
      • A second dialogue box will pop up prompting for acknowledgement that verifying your startup disk will cause it to be non-responsive.
      • Click “Continue”.
      Спросите у FixBot
    5. How to Run First Aid with Disk Utility: шаг 5, изображение 1 из 3 How to Run First Aid with Disk Utility: шаг 5, изображение 2 из 3 How to Run First Aid with Disk Utility: шаг 5, изображение 3 из 3
      • This procedure will take a few minutes to complete. The machine may freeze up, or lock up during this procedure.
      • Patience is key here.
      • Disk repair may fail, or give an error message. Restart your machine and run it again if this is the case, it may repair further issues.
      • Once completed, click done.
      • Pro Tip: To see the entire process including corrected errors, click on the arrow next to 'Show Details'.
      • Repeat this on all items in the Disk Utility list for your internal drive. Move upward through the list. Order of operations is all volumes first, then the container and finally the disk itself.
      Спросите у FixBot
    6. How to Run First Aid with Disk Utility: шаг 6, изображение 1 из 1
      • If you continue to receive errors, repeat this process using the Disk Utility function in Internet Recovery.
      Спросите у FixBot
Заключение
Close Disk Utility, and the internal drive should be ready to go.
44 человек успешно провели ремонт по этому руководству.
Mike
Участник с: 11/01/10
14 505 Репутация
Автор 3 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 52
За последние 30 дней: 271
За всё время: 23,201
